"Strange behaviour of impute missing values component [Solved]"
User: "ammargh"
New Altair Community Member
Updated by Jocelyn
Using Rapidminer 5.3.015
I am trying to process missing values.
After retrieving the data I used a multiply component. One of the multiply component's output is used as an input to the impute missing values component and a second output is connected to the process res port.
After running the process missing values both before and after the impute missing values were replaced !!.
This is strange because the original data should not be changed !!!
(Edited:  Same results with RM Studio 6.0.3)
<process version="5.3.015">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
   <process expanded="true">
     <operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30">
       <parameter key="repository_entry" value="//Samples/data/Labor-Negotiations"/>
     <operator activated="true" class="multiply" compatibility="5.3.015" expanded="true" height="94" name="Multiply" width="90" x="179" y="165"/>
     <operator activated="true" class="impute_missing_values" compatibility="5.3.015" expanded="true" height="60" name="Impute Missing Values" width="90" x="447" y="255">
       <parameter key="attribute" value="class"/>
         <operator activated="true" class="k_nn" compatibility="5.3.015" expanded="true" height="76" name="k-NN" width="90" x="601" y="30">
           <parameter key="k" value="5"/>
         <connect from_port="example set source" to_op="k-NN" to_port="training set"/>
         <connect from_op="k-NN" from_port="model" to_port="model sink"/>
         <portSpacing port="source_example set source" spacing="0"/>
         <portSpacing port="sink_model sink" spacing="0"/>
       </process>
     <connect from_op="Retrieve" from_port="output" to_op="Multiply" to_port="input"/>
     <connect from_op="Multiply" from_port="output 1" to_op="Impute Missing Values" to_port="example set in"/>
     <connect from_op="Multiply" from_port="output 2" to_port="result 2"/>
     <connect from_op="Impute Missing Values" from_port="example set out" to_port="result 1"/>
   </process>
</process>
1 - 2 of 21
    User: "Marco_Boeck"
    while most operators work on a view of the data, i.e. do not modify the underlying data, some do. This is sort of a mixture between internal restrictions and a bug. You can work around this by adding a "Materialize Data" operator after the "Multiply" for the connection which should return the original example set. See the following example process:
    <process version="6.0.006">
     <context>
       <input/>
       <output/>
       <macros/>
     </context>
     <operator activated="true" class="process" compatibility="6.0.006" expanded="true" name="Process">
         <operator activated="true" class="retrieve" compatibility="6.0.006" expanded="true" height="60" name="Retrieve Labor-Negotiations" width="90" x="45" y="75">
         <operator activated="true" class="multiply" compatibility="6.0.006" expanded="true" height="94" name="Multiply" width="90" x="246" y="75"/>
         <operator activated="true" class="materialize_data" compatibility="6.0.006" expanded="true" height="76" name="Materialize Data" width="90" x="380" y="30"/>
         <operator activated="true" class="impute_missing_values" compatibility="6.0.006" expanded="true" height="60" name="Impute Missing Values" width="90" x="379" y="120">
             <operator activated="true" class="k_nn" compatibility="6.0.006" expanded="true" height="76" name="k-NN" width="90" x="112" y="30"/>
           </process>
         <connect from_op="Retrieve Labor-Negotiations" from_port="output" to_op="Multiply" to_port="input"/>
         <connect from_op="Multiply" from_port="output 1" to_op="Materialize Data" to_port="example set input"/>
         <connect from_op="Multiply" from_port="output 2" to_op="Impute Missing Values" to_port="example set in"/>
         <connect from_op="Materialize Data" from_port="example set output" to_port="result 1"/>
         <connect from_op="Impute Missing Values" from_port="example set out" to_port="result 2"/>
       </process>
    </process>
    Marco
    User: "ammargh"
    OP
    Thank you very much.
