[SOLVED] Extract location of current process to data
JEdward
New Altair Community Member
Hi all,
I had an idea that I could extract the location of a current process using Log & Log to Data operators. However, although the value prints to the console I can't see anything on the results page just a blank attribute. Have I done something wrong? Should I use a different operator?
It works if I store the log value as a Filename, but I don't want to do this as I just want the datavalue.
<process version="5.3.015">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="log" compatibility="5.3.015" expanded="true" height="76" name="Log" width="90" x="45" y="30">
<list key="log">
<parameter key="FileName" value="operator.Log.parameter.filename"/>
</list>
<operator activated="true" class="print_to_console" compatibility="5.3.015" expanded="true" height="76" name="Print to Console" width="90" x="112" y="120">
<parameter key="log_value" value="FileName"/>
<operator activated="true" class="log_to_data" compatibility="5.3.015" expanded="true" height="94" name="Log to Data" width="90" x="246" y="30"/>
<connect from_op="Log" from_port="through 1" to_op="Print to Console" to_port="through 1"/>
<connect from_op="Print to Console" from_port="through 1" to_op="Log to Data" to_port="through 1"/>
<connect from_op="Log to Data" from_port="exampleSet" to_port="result 1"/>
</process>
</process>
is that what you want?
<process version="6.0.006">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
<operator activated="true" class="log" compatibility="6.0.006" expanded="true" height="76" name="Log" width="90" x="45" y="30">
<list key="log">
<parameter key="FileName" value="operator.Print to Console.parameter.log_value"/>
</list>
<operator activated="true" class="print_to_console" compatibility="6.0.006" expanded="true" height="76" name="Print to Console" width="90" x="179" y="30">
<parameter key="log_value" value="%{process_path}"/>
<operator activated="true" class="log_to_data" compatibility="6.0.006" expanded="true" height="94" name="Log to Data" width="90" x="313" y="30"/>
</process>
</process>
Marco0 -
Exactly!
But all I really needed was:
I should really read the manual for reserved macros.<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="generate_data_user_specification" compatibility="5.3.015" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="30">
<list key="attribute_values">
<parameter key="ProPath" value=""%{process_path}""/>
</list>
<connect from_op="Generate Data by User Specification" from_port="output" to_port="result 1"/>
</process>
</process>0
