Dear Rapidminer community,
I have a table of let's say 1 label and 5 regular attributes.
The goal is to write the mutual information between the label and each regular attribute as the weight of each regular attribute (e.g. mutual information between label and att1 = 2,452 -> This shall become the weight of att1; similar for att2 to att5).
So far I managed to write the mutual information to an excel file. (Which works though I have to admit that I don't really understand the necessaty to have the second report operator. But be it as it may.)
<process version="6.0.003">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.003" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data" compatibility="6.0.003" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/>
<operator activated="true" class="set_role" compatibility="6.0.003" expanded="true" height="76" name="Set Role" width="90" x="179" y="30">
<parameter key="attribute_name" value="label"/>
<operator activated="true" class="mututal_information_matrix" compatibility="6.0.003" expanded="true" height="76" name="Mutual Information Matrix" width="90" x="313" y="30"/>
<operator activated="true" class="reporting:generate_report" compatibility="5.3.000" expanded="true" height="76" name="Generate Report" width="90" x="447" y="30">
<parameter key="report_name" value="report"/>
<parameter key="format" value="Excel"/>
<parameter key="excel_output_file" value="C:\Users\Abc\Desktop\mutual information.xls"/>
<operator activated="true" class="reporting:report" compatibility="5.3.000" expanded="true" height="60" name="Report" width="90" x="581" y="30">
<parameter key="specified" value="true"/>
<parameter key="reportable_type" value="Numerical Matrix"/>
<parameter key="renderer_name" value="Table View"/>
<list key="parameters">
<parameter key="min_row" value="1"/>
<parameter key="max_row" value="2147483647"/>
<parameter key="min_column" value="1"/>
<parameter key="max_column" value="2147483647"/>
</list>
<connect from_op="Generate Data" from_port="output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Mutual Information Matrix" to_port="example set"/>
<connect from_op="Mutual Information Matrix" from_port="matrix" to_op="Generate Report" to_port="through 1"/>
<connect from_op="Generate Report" from_port="through 1" to_op="Report" to_port="reportable in"/>
<connect from_op="Report" from_port="reportable out" to_port="result 1"/>
</process>
</process>
The point where I am struggling is to transfer the matrix output into weights.
Maybe it is not necessary to write a report file at all but at the moment I am totally stuck. Any help is greatly appreciated.
Cheers
Sachs
