<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve Golf" width="90" x="179" y="30"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="set_role" compatibility="5.3.015" expanded="true" height="76" name="Set Role" width="90" x="313" y="30"> <parameter key="attribute_name" value="Play"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="nominal_to_numerical" compatibility="5.3.015" expanded="true" height="94" name="Nominal to Numerical" width="90" x="447" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Outlook|Wind|"/> <parameter key="coding_type" value="unique integers"/> <list key="comparison_groups"/> </operator> <operator activated="true" class="logistic_regression" compatibility="5.3.015" expanded="true" height="94" name="Logistic Regression (2)" width="90" x="581" y="30"/> <connect from_op="Retrieve Golf" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Nominal to Numerical" to_port="example set input"/> <connect from_op="Nominal to Numerical" from_port="example set output" to_op="Logistic Regression (2)" to_port="training set"/> <connect from_op="Logistic Regression (2)" from_port="model" to_port="result 1"/> <connect from_op="Logistic Regression (2)" from_port="weights" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
