<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve Iris" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="subprocess" compatibility="5.3.015" expanded="true" height="76" name="TrainingSetSimulation" width="90" x="45" y="120"> <description>This uses a Select Attibutes Operator to simulate your training set. </description> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve Iris (2)" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.015" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|a1|a4|id|label"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="filter_example_range" compatibility="5.3.015" expanded="true" height="76" name="Filter Example Range" width="90" x="313" y="30"> <description>You only need one example. You would store this result with the model to use in preprocessing as a reference set in Reorder Attributes.</description> <parameter key="first_example" value="1"/> <parameter key="last_example" value="1"/> </operator> <connect from_op="Retrieve Iris (2)" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="order_attributes" compatibility="5.3.015" expanded="true" height="76" name="Reorder Attributes" width="90" x="246" y="30"> <parameter key="sort_mode" value="reference data"/> <parameter key="handle_unmatched" value="remove"/> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Reorder Attributes" to_port="example set input"/> <connect from_op="TrainingSetSimulation" from_port="out 1" to_op="Reorder Attributes" to_port="reference_data"/> <connect from_op="Reorder Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
