Marco Boeck wrote:Hi,the decision tree is not an updatable model. You will have to relearn a new one on the updated training data. The only updatable models in the core of Studio currently are k-NN and Naive Bayes.Regards,Marco
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.006" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_nominal_data" compatibility="6.0.006" expanded="true" height="60" name="Generate Nominal Data (2)" width="90" x="45" y="165"> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="2014"/> </operator> <operator activated="true" class="generate_nominal_data" compatibility="6.0.006" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="30"> <parameter key="use_local_random_seed" value="true"/> </operator> <operator activated="true" class="naive_bayes" compatibility="6.0.006" expanded="true" height="76" name="Naive Bayes" width="90" x="179" y="30"/> <operator activated="true" class="store" compatibility="6.0.006" expanded="true" height="60" name="Store" width="90" x="313" y="30"> <parameter key="repository_entry" value="originalModel"/> </operator> <operator activated="true" class="retrieve" compatibility="6.0.006" expanded="true" height="60" name="Retrieve" width="90" x="514" y="165"> <parameter key="repository_entry" value="originalModel"/> </operator> <operator activated="true" class="update_model" compatibility="6.0.006" expanded="true" height="76" name="Update Model" width="90" x="514" y="75"/> <connect from_op="Generate Nominal Data (2)" from_port="output" to_op="Update Model" to_port="example set"/> <connect from_op="Generate Nominal Data" from_port="output" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_op="Store" to_port="input"/> <connect from_op="Store" from_port="through" to_op="Update Model" to_port="model"/> <connect from_op="Retrieve" from_port="output" to_port="result 2"/> <connect from_op="Update Model" from_port="model" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_nominal_data" compatibility="5.3.015" expanded="true" height="60" name="Generate Nominal Data (2)" width="90" x="45" y="165"> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="2014"/> </operator> <operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve newData" width="90" x="45" y="300"> <parameter key="repository_entry" value="newData"/> </operator> <operator activated="true" class="generate_nominal_data" compatibility="5.3.015" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="30"> <parameter key="use_local_random_seed" value="true"/> </operator> <operator activated="true" class="naive_bayes" compatibility="5.3.015" expanded="true" height="76" name="Naive Bayes" width="90" x="179" y="30"/> <operator activated="true" class="store" compatibility="5.3.015" expanded="true" height="60" name="Store" width="90" x="313" y="30"> <parameter key="repository_entry" value="//NewLocalRepository/originalModel"/> </operator> <operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve originalModel" width="90" x="1050" y="300"> <parameter key="repository_entry" value="//NewLocalRepository/originalModel"/> </operator> <operator activated="true" class="update_model" compatibility="5.3.015" expanded="true" height="76" name="Update Model" width="90" x="447" y="210"/> <operator activated="true" class="apply_model" compatibility="5.3.015" expanded="true" height="76" name="Apply Model" width="90" x="648" y="210"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_classification" compatibility="5.3.015" expanded="true" height="76" name="Performance" width="90" x="782" y="30"> <parameter key="kappa" value="true"/> <parameter key="root_mean_squared_error" value="true"/> <parameter key="root_relative_squared_error" value="true"/> <parameter key="correlation" value="true"/> <list key="class_weights"/> </operator> <operator activated="true" class="store" compatibility="5.3.015" expanded="true" height="60" name="Store (2)" width="90" x="916" y="120"> <parameter key="repository_entry" value="newData"/> </operator> <connect from_op="Retrieve newData" from_port="output" to_op="Update Model" to_port="example set"/> <connect from_op="Generate Nominal Data" from_port="output" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_op="Store" to_port="input"/> <connect from_op="Store" from_port="through" to_op="Update Model" to_port="model"/> <connect from_op="Retrieve originalModel" from_port="output" to_port="result 3"/> <connect from_op="Update Model" from_port="example set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Update Model" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <connect from_op="Performance" from_port="example set" to_op="Store (2)" to_port="input"/> <connect from_op="Store (2)" from_port="through" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
Marco Boeck wrote:Hi,see the following example process which you just need to save in your repository: <?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.006" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_nominal_data" compatibility="6.0.006" expanded="true" height="60" name="Generate Nominal Data (2)" width="90" x="45" y="165"> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="2014"/> </operator> <operator activated="true" class="generate_nominal_data" compatibility="6.0.006" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="30"> <parameter key="use_local_random_seed" value="true"/> </operator> <operator activated="true" class="naive_bayes" compatibility="6.0.006" expanded="true" height="76" name="Naive Bayes" width="90" x="179" y="30"/> <operator activated="true" class="store" compatibility="6.0.006" expanded="true" height="60" name="Store" width="90" x="313" y="30"> <parameter key="repository_entry" value="originalModel"/> </operator> <operator activated="true" class="retrieve" compatibility="6.0.006" expanded="true" height="60" name="Retrieve" width="90" x="514" y="165"> <parameter key="repository_entry" value="originalModel"/> </operator> <operator activated="true" class="update_model" compatibility="6.0.006" expanded="true" height="76" name="Update Model" width="90" x="514" y="75"/> <connect from_op="Generate Nominal Data (2)" from_port="output" to_op="Update Model" to_port="example set"/> <connect from_op="Generate Nominal Data" from_port="output" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_op="Store" to_port="input"/> <connect from_op="Store" from_port="through" to_op="Update Model" to_port="model"/> <connect from_op="Retrieve" from_port="output" to_port="result 2"/> <connect from_op="Update Model" from_port="model" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process> Regards,Marco
