<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="subprocess" compatibility="5.3.015" expanded="true" height="94" name="GetTrend" width="90" x="179" y="30"> <process expanded="true"> <operator activated="true" class="quantx1:world_bank_data_extractor" compatibility="1.0.006" expanded="true" height="60" name="World Bank Data Extractor" width="90" x="45" y="30"> <parameter key="Select Indicator" value="SP.POP.TOTL"/> <parameter key="Start Year" value="1950"/> <parameter key="End Year" value="2000"/> <parameter key="Country" value="Germany"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.015" expanded="true" height="76" name="Select Attributes" width="90" x="180" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|Year|Value"/> </operator> <operator activated="true" class="set_role" compatibility="5.3.015" expanded="true" height="76" name="Set Role" width="90" x="315" y="30"> <parameter key="attribute_name" value="Year"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"> <parameter key="Value" value="label"/> </list> </operator> <operator activated="true" class="series:fit_trend" compatibility="5.3.000" expanded="true" height="60" name="Fit Trend" width="90" x="313" y="165"> <parameter key="attribute" value="Value"/> <process expanded="true"> <operator activated="true" class="neural_net" compatibility="5.3.015" expanded="true" name="Neural Net (2)"> <list key="hidden_layers"/> </operator> <operator activated="true" class="remember" compatibility="5.3.015" expanded="true" name="Remember"> <parameter key="name" value="Trend"/> <parameter key="io_object" value="Model"/> </operator> <connect from_port="example set" to_op="Neural Net (2)" to_port="training set"/> <connect from_op="Neural Net (2)" from_port="model" to_op="Remember" to_port="store"/> <connect from_op="Remember" from_port="stored" to_port="model"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> </process> </operator> <connect from_op="World Bank Data Extractor" from_port="example set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Fit Trend" to_port="example set"/> <connect from_op="Fit Trend" from_port="example set with trend" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> <portSpacing port="sink_out 3" spacing="0"/> </process> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.015" expanded="true" height="60" name="EnterYearHere" width="90" x="45" y="165"> <list key="attribute_values"> <parameter key="Year" value="2053"/> </list> <list key="set_additional_roles"> <parameter key="Year" value="id"/> </list> </operator> <operator activated="true" class="subprocess" compatibility="5.3.015" expanded="true" height="94" name="ApplyTrend" width="90" x="179" y="165"> <process expanded="true"> <operator activated="true" class="recall" compatibility="5.3.015" expanded="true" height="60" name="Recall" width="90" x="180" y="30"> <parameter key="name" value="Trend"/> <parameter key="io_object" value="Model"/> <parameter key="remove_from_store" value="false"/> </operator> <operator activated="true" class="apply_model" compatibility="5.3.015" expanded="true" height="76" name="Apply Model" width="90" x="315" y="30"> <list key="application_parameters"/> </operator> <connect from_port="in 1" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Recall" from_port="result" to_op="Apply Model" to_port="model"/> <connect from_op="Apply Model" from_port="labelled data" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="source_in 3" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="GetTrend" from_port="out 1" to_port="result 1"/> <connect from_op="GetTrend" from_port="out 2" to_op="ApplyTrend" to_port="in 2"/> <connect from_op="EnterYearHere" from_port="output" to_op="ApplyTrend" to_port="in 1"/> <connect from_op="ApplyTrend" from_port="out 1" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
Those is for? because I need predict or forecast piping failures in a Distribution network of drinking water in a determinated place, I hace to put this programming code or i can build this model with the tools of RapidMiner?
Thanks you a lot of...
