<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.015" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="30"> <list key="attribute_values"> <parameter key="Real" value="0.0000123"/> <parameter key="Nominal" value=""0.0000123""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.015" expanded="true" height="76" name="Generate Attributes" width="90" x="179" y="30"> <list key="function_descriptions"> <parameter key="RealtoString" value="str(Real)"/> <parameter key="RealMultiplied" value="Real*10000"/> <parameter key="RealWithFormat" value="Real"/> </list> </operator> <operator activated="true" class="format_numbers" compatibility="5.3.015" expanded="true" height="76" name="Format Numbers" width="90" x="380" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="RealWithFormat"/> <parameter key="format_type" value="pattern"/> <parameter key="pattern" value="#.###############"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Format Numbers" to_port="example set input"/> <connect from_op="Format Numbers" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
