<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.015" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="45" y="75"> <list key="attribute_values"> <parameter key="A" value=""Jimmy""/> <parameter key="B" value=""Stewart""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.015" expanded="true" height="76" name="Generate Attributes" width="90" x="313" y="30"> <list key="function_descriptions"> <parameter key="C" value="if(missing(A),B,concat(A,B))"/> </list> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.015" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="45" y="165"> <list key="attribute_values"> <parameter key="B" value=""Stewart""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_empty_attribute" compatibility="5.3.015" expanded="true" height="76" name="Generate Empty Attribute" width="90" x="179" y="165"> <parameter key="name" value="A"/> <parameter key="value_type" value="nominal"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.015" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="380" y="165"> <list key="function_descriptions"> <parameter key="C" value="if(missing(A),B,concat(A,B))"/> </list> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Generate Empty Attribute" to_port="example set input"/> <connect from_op="Generate Empty Attribute" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
