Daily hour sums on multi-day spans of time
I have an example set from a spreadsheet that has start and end times which can span multiple days, and I need the total number of hours per day that this time spanned.
For instance, if I have one record with a start time of May 15, 2014 11:00 and an end time of May 15, 2014 14:00, the result should be:
May 15, 2014 3
The more difficult case is when I have one record with a start time of May 15, 2014 09:00 and an end time of May 18, 2014 22:00, I need the following result:
May 15, 2014 16
May 16, 2014 24
May 17, 2014 24
May 18, 2014 22
Then I need to sum the totals per day. So for an example set containing the two records mentioned above, the result would be:
May 15, 2014 19
May 16, 2014 24
May 17, 2014 24
May 18, 2014 22
The approach I am trying is to create extra examples for each of the in-between days (May 16 and 17 in the above example) and assign them 24 hours. But I am having trouble with this. I know how to loop through the example set and create a single new example for each day individually, but I don't know how to then connect ALL of those new examples to the original example set (my first attempt UNIONed only the last one from the loop to the set).
Can anyone help with how to do this, or a better way to solve the overall problem?
Thanks,
Kelly
