<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve Model" width="90" x="45" y="30"> <parameter key="repository_entry" value="//NewLocalRepository/Virtualization/Disruption Prediction Model/Realtime Predictions/Modeling/Model"/> </operator> <operator activated="true" class="read_database" compatibility="5.3.015" expanded="true" height="60" name="Read Database" width="90" x="45" y="210"> <parameter key="connection" value="MySQL"/> <parameter key="query" value="SELECT `title`, `clean_text` FROM `potential_tech_disruptions_clean_data_tbl`"/> <enumeration key="parameters"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.015" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="210"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="clean_text|title|"/> </operator> <operator activated="true" class="nominal_to_text" compatibility="5.3.015" expanded="true" height="76" name="Nominal to Text" width="90" x="313" y="210"> <parameter key="attributes" value="|title|clean_text"/> </operator> <operator activated="true" class="text:process_document_from_data" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Data (2)" width="90" x="447" y="210"> <parameter key="keep_text" value="true"/> <parameter key="prune_method" value="absolute"/> <parameter key="prune_below_percent" value="0.0"/> <parameter key="prune_above_percent" value="10.0"/> <parameter key="prune_below_absolute" value="2"/> <parameter key="prune_above_absolute" value="99999"/> <parameter key="prune_below_rank" value="0.5"/> <list key="specify_weights"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize (2)" width="90" x="45" y="30"/> <operator activated="true" class="text:transform_cases" compatibility="5.3.002" expanded="true" height="60" name="Transform Cases (2)" width="90" x="180" y="30"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (2)" width="90" x="315" y="30"/> <operator activated="true" class="text:stem_snowball" compatibility="5.3.002" expanded="true" height="60" name="Stem (2)" width="90" x="450" y="30"/> <operator activated="true" class="text:generate_n_grams_terms" compatibility="5.3.002" expanded="true" height="60" name="Generate n-Grams (2)" width="90" x="313" y="165"> <parameter key="max_length" value="3"/> </operator> <operator activated="true" class="text:filter_by_length" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (2)" width="90" x="447" y="165"> <parameter key="min_chars" value="3"/> <parameter key="max_chars" value="125"/> </operator> <connect from_port="document" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/> <connect from_op="Transform Cases (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/> <connect from_op="Filter Stopwords (2)" from_port="document" to_op="Stem (2)" to_port="document"/> <connect from_op="Stem (2)" from_port="document" to_op="Generate n-Grams (2)" to_port="document"/> <connect from_op="Generate n-Grams (2)" from_port="document" to_op="Filter Tokens (2)" to_port="document"/> <connect from_op="Filter Tokens (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="apply_model" compatibility="5.3.015" expanded="true" height="76" name="Apply Model (2)" width="90" x="179" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.015" expanded="true" height="76" name="Select Attributes (2)" width="90" x="313" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|title|confidence(N)|confidence(Y)|prediction(Disruptive)"/> </operator> <operator activated="true" class="write_database" compatibility="5.3.015" expanded="true" height="60" name="Write Database" width="90" x="447" y="30"> <parameter key="connection" value="MySQL"/> <parameter key="table_name" value="predicted_disruption_tbl2"/> <parameter key="overwrite_mode" value="overwrite"/> <parameter key="set_default_varchar_length" value="true"/> <parameter key="default_varchar_length" value="255"/> </operator> <connect from_op="Retrieve Model" from_port="output" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Read Database" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data (2)" to_port="example set"/> <connect from_op="Process Documents from Data (2)" from_port="example set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Write Database" to_port="input"/> <connect from_op="Write Database" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
