<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.003" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_team_profit_data" compatibility="6.0.003" expanded="true" height="60" name="Generate Team Profit Data" width="90" x="45" y="75"/> <operator activated="true" class="aggregate" compatibility="6.0.003" expanded="true" height="76" name="Aggregate" width="90" x="179" y="75"> <list key="aggregation_attributes"> <parameter key="average years of experience" value="sum"/> </list> <parameter key="group_by_attributes" value="leader"/> </operator> <operator activated="true" class="join" compatibility="6.0.003" expanded="true" height="76" name="Join" width="90" x="313" y="75"> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="leader" value="leader"/> </list> </operator> <operator activated="true" class="nominal_to_numerical" compatibility="6.0.003" expanded="true" height="94" name="Nominal to Numerical" width="90" x="447" y="75"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="leader"/> <list key="comparison_groups"/> </operator> <connect from_op="Generate Team Profit Data" from_port="output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Aggregate" from_port="original" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_op="Nominal to Numerical" to_port="example set input"/> <connect from_op="Nominal to Numerical" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
