This is a really simple problem, but for some reason I just can't get it.
I'd like to loop through the attributes of a dataset to create counts againts each variable against the label. (This can later become percentages or index)
If there is a numeric attribute to discretize it, otherwise to show the groups.
So for example using the golf dataset I'd get something like:
| Temperature | Play: Yes | Play: No |
| range1 [-∞ - 73.500] | 5 | 3 |
| range2 [73.500 - ∞] | 4 | 2 |
| Outlook | Play: Yes | Play: No |
| overcast | 4 | 0 |
| rain | 3 | 2 |
| sunny | 2 | 3 |
For some reason I just can't work out a way of extracting this data in an automated way... can anyone help my ignorance?
Thanks,
JEdward
Here's my current XML: I have tried using Loop Attributes to step through each variable, but this seems to cause errors and so to get the values I need to manually change the value in Select Attributes & Pivot individually (Aggregate ignores values it can't count so I put all possible attributes in there).
<process version="5.3.015">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Golf" width="90" x="45" y="30">
<parameter key="repository_entry" value="//Samples/data/Golf"/>
<operator activated="true" class="subprocess" compatibility="5.3.015" expanded="true" height="76" name="Numeric" width="90" x="112" y="165">
<operator activated="true" class="discretize_by_frequency" compatibility="5.3.015" expanded="true" height="94" name="Discretize" width="90" x="246" y="30">
<parameter key="number_of_bins" value="5"/>
<connect from_port="in 1" to_op="Discretize" to_port="example set input"/>
<connect from_op="Discretize" from_port="example set output" to_port="out 1"/>
<portSpacing port="source_in 2" spacing="0"/>
</process>
<operator activated="true" class="select_attributes" compatibility="5.3.015" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30">
<parameter key="attribute" value="Humidity"/>
<operator activated="true" class="aggregate" compatibility="5.3.015" expanded="true" height="76" name="Aggregate" width="90" x="246" y="165">
<parameter key="use_default_aggregation" value="true"/>
<parameter key="attribute" value="Play"/>
<parameter key="default_aggregation_function" value="count"/>
<parameter key="Play" value="count"/>
</list>
<parameter key="group_by_attributes" value="Play|Outlook|Humidity|Temperature|Wind"/>
<operator activated="true" class="pivot" compatibility="5.3.015" expanded="true" height="76" name="Pivot" width="90" x="380" y="165">
<parameter key="group_attribute" value="Humidity"/>
<parameter key="index_attribute" value="Play"/>
<operator activated="true" class="replace_missing_values" compatibility="5.3.015" expanded="true" height="94" name="Replace Missing Values" width="90" x="380" y="30">
<parameter key="attributes" value="|count(Play)_no|count(Play)_yes"/>
<parameter key="default" value="zero"/>
<list key="columns"/>
<operator activated="true" class="order_attributes" compatibility="5.3.015" expanded="true" height="76" name="Reorder Attributes" width="90" x="506" y="30">
<parameter key="sort_direction" value="descending"/>
<parameter key="attribute_ordering" value="count(Play)_yes|count(Play)_no"/>
<parameter key="handle_unmatched" value="prepend"/>
<connect from_op="Golf" from_port="output" to_op="Numeric" to_port="in 1"/>
<connect from_op="Numeric" from_port="out 1" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Aggregate" to_port="example set input"/>
<connect from_op="Aggregate" from_port="example set output" to_op="Pivot" to_port="example set input"/>
<connect from_op="Pivot" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/>
<connect from_op="Replace Missing Values" from_port="example set output" to_op="Reorder Attributes" to_port="example set input"/>
<connect from_op="Reorder Attributes" from_port="example set output" to_port="result 1"/>
</process>
</process>
