<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.003"> <context> <input/> <output/> <macros> <macro> <key>input</key> <value>http://pastebin.com/raw.php?i=3guyR6H5</value> </macro> </macros> </context> <operator activated="true" class="process" compatibility="6.0.003" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="6.0.003" expanded="true" height="60" name="Read CSV" width="90" x="45" y="75"> <parameter key="csv_file" value="C:\Users\fras\AppData\Local\Temp\rm_file_6786169822975474295.dump"/> <parameter key="column_separators" value="'\n""/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"/> <parameter key="encoding" value="windows-1252"/> <list key="data_set_meta_data_information"> <parameter key="0" value="att1.true.polynominal.attribute"/> </list> </operator> <operator activated="true" class="split" compatibility="6.0.003" expanded="true" height="76" name="Split" width="90" x="246" y="75"> <parameter key="split_pattern" value="\s"/> </operator> <operator activated="true" class="rename_by_example_values" compatibility="6.0.003" expanded="true" height="76" name="Rename by Example Values" width="90" x="447" y="75"/> <connect from_op="Read CSV" from_port="output" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_op="Rename by Example Values" to_port="example set input"/> <connect from_op="Rename by Example Values" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
