SimLab 2021 is not installing under master installer. Please help. Error message below.
Can you please check if your installation file isn't corrupted by comparing the expected checksum code?
This topic in the Community shows how to obtain the checksum code of your downloaded file.
Then you need to compare with the expected one (from Altair Connect)
https://community.altair.com/community?id=community_blog&sys_id=98f4a4d4dbf060d0e8863978f49619ff&view_source=searchResult
Also make sure no special characters present in your folders, nor permission issues for writting into the installation folder.
