<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.003" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.0.003" expanded="true" height="60" name="Retrieve Sonar" width="90" x="112" y="30"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="loop_attributes" compatibility="6.0.003" expanded="true" height="94" name="Loop Attributes" width="90" x="246" y="30"> <parameter key="iteration_macro" value="a1"/> <process expanded="true"> <operator activated="true" class="loop_attributes" compatibility="6.0.003" expanded="true" height="94" name="Loop Attributes (2)" width="90" x="45" y="30"> <parameter key="iteration_macro" value="a2"/> <process expanded="true"> <operator activated="true" class="branch" compatibility="6.0.003" expanded="true" height="94" name="Branch" width="90" x="45" y="30"> <parameter key="condition_type" value="expression"/> <parameter key="condition_value" value=""%{a1}" != "%{a2}""/> <process expanded="true"> <operator activated="true" class="select_attributes" compatibility="6.0.003" expanded="true" height="76" name="Select Attributes" width="90" x="44" y="30"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="%{a1}|%{a2}"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="set_role" compatibility="6.0.003" expanded="true" height="76" name="Set Role" width="90" x="178" y="30"> <parameter key="attribute_name" value="%{a2}"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="linear_regression" compatibility="6.0.003" expanded="true" height="94" name="Linear Regression" width="90" x="313" y="30"> <parameter key="feature_selection" value="none"/> <parameter key="eliminate_colinear_features" value="false"/> </operator> <operator activated="true" class="weights_to_data" compatibility="6.0.003" expanded="true" height="60" name="Weights to Data" width="90" x="446" y="30"/> <operator activated="true" class="generate_attributes" compatibility="6.0.003" expanded="true" height="76" name="Generate Attributes" width="90" x="581" y="30"> <list key="function_descriptions"> <parameter key="label" value=""%{a2}""/> </list> </operator> <connect from_port="input 1" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Linear Regression" to_port="training set"/> <connect from_op="Linear Regression" from_port="weights" to_op="Weights to Data" to_port="attribute weights"/> <connect from_op="Weights to Data" from_port="example set" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> <process expanded="true"> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Branch" to_port="input 1"/> <connect from_op="Branch" from_port="input 1" to_port="result 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Loop Attributes (2)" to_port="example set"/> <connect from_op="Loop Attributes (2)" from_port="result 1" to_port="result 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="6.0.003" expanded="true" height="76" name="Append" width="90" x="380" y="30"/> <connect from_op="Retrieve Sonar" from_port="output" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="result 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
WekaClassifier classifier = (WekaClassifier)input[0];J48 j48 = classifier.getClassifier();LogService.getRoot().log(Level.INFO, "WEKA TREE SIZE: "+j48.measureTreeSize());LogService.getRoot().log(Level.INFO, "WEKA LEAF NUMBER: "+j48.measureNumLeaves());
