Hı
I am trying to analyze with very easy model but I am getting an error. I don't understand why is it causing the error?
I'm sharing my file.
Thank you.
The error is due to bad quality of elements. You can bypass element check using CHECKEL>> NO,
Go to Control cards>> PARAM>>CHECKEL>>NO, add the same and run the analysis.
Thank you:) @Prakash Pagadala
