"Freezing On Initializing XML Transformation Rules (Mac 10.9)"
Hi all, i'll try to be as detailed as possible with what i've tried etc, so when opening rapidminer it just stops on the Initalizing XML Transformation Rules on my mac running 10.9.2.
I've emailed support and had some help earlier today but having no luck getting passed this problem, when using terminal to check what version on Java i have running its saying 1.8.0 with JDK 8 installed when previously was 1.7, i deleted files so it went back to 1.6something then i got it to 1.8 to try getting it to work, i seen a post about the same problem where to put in a line of code into terminal to get it to work but when i entered it this came up in my terminal -
Last login: Wed Apr 2 21:31:43 on ttys000
chriscosmacbook:~ chriscorner$ java -Xdebug -Xnoagent -Djava.compiler=NONE -Xrunjdwp:transport=dt_socket,address=localhost:40000,server=y,suspend=n -jar lib/rapidminer.jar
Error: Unable to access jarfile lib/rapidminer.jar
chriscosmacbook:~ chriscorner$ /Users/chriscorner/rapidminer-studio/lib/rapidminer.jar
-bash: /Users/chriscorner/rapidminer-studio/lib/rapidminer.jar: Permission denied
chriscosmacbook:~ chriscorner$ java -Xdebug -Xnoagent -Djava.compiler=NONE -Xrunjdwp:transport=dt_socket,address=localhost:40000,server=y,suspend=n -jar /Users/chriscorner/rapidminer-studio/lib/rapidminer.jar
Listening for transport dt_socket at address: 40000
Apr 02, 2014 10:20:13 PM com.rapidminer.gui.safemode.SafeMode launchStarts
INFO: Found left-behind lock file from last startup at /Users/chriscorner/.RapidMiner/safeMode.lock.
Apr 02, 2014 10:20:13 PM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
Apr 02, 2014 10:20:26 PM com.rapidminer.gui.safemode.SafeMode launchStarts
INFO: com.rapidminer.gui.safemode.SafeMode.entering_safe_mode
Apr 02, 2014 10:20:26 PM com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: Property rapidminer.home is not set. Guessing.
INFO: Trying parent directory of '/Users/chriscorner/rapidminer-studio/lib/rapidminer.jar'...gotcha!
Apr 02, 2014 10:20:26 PM com.rapidminer.license.ProductConstraintManager initialize
INFO: Initializing license manager.
INFO: Using default license location.
Apr 02, 2014 10:20:28 PM com.rapidminer.license.ProductConstraintManager initialize
INFO: Registering default product.
Apr 02, 2014 10:20:28 PM com.rapidminer.tools.plugin.Plugin initAll
INFO: Plugins skipped.
Apr 02, 2014 10:20:29 PM com.rapidminer.tools.OperatorService registerOperators
SEVERE: Cannot read operator description file OperatorsCore.xml: no valid XML: Can't find bundle for base name com/rapidminer/resources/i18n/OperatorsCoreDocumentation, locale en
java.util.MissingResourceException: Can't find bundle for base name com/rapidminer/resources/i18n/OperatorsCoreDocumentation, locale en
at java.util.ResourceBundle.throwMissingResourceException(ResourceBundle.java:1564)
at java.util.ResourceBundle.getBundleImpl(ResourceBundle.java:1387)
at java.util.ResourceBundle.getBundle(ResourceBundle.java:1299)
at com.rapidminer.tools.documentation.XMLOperatorDocBundle.load(XMLOperatorDocBundle.java:175)
at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:236)
at com.rapidminer.tools.OperatorService.registerOperators(OperatorService.java:200)
at com.rapidminer.tools.OperatorService.registerOperators(OperatorService.java:172)
at com.rapidminer.tools.OperatorService.init(OperatorService.java:113)
at com.rapidminer.RapidMiner.init(RapidMiner.java:639)
at com.rapidminer.RapidMiner.init(RapidMiner.java:583)
at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:298)
at com.rapidminer.gui.RapidMinerGUI.launch(RapidMinerGUI.java:757)
at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:738)
Caused by: java.lang.AbstractMethodError: org.apache.xerces.dom.DeferredElementImpl.getTextContent()Ljava/lang/String;
at com.rapidminer.io.process.XMLTools.getTagContents(XMLTools.java:311)
at com.rapidminer.io.process.XMLTools.getTagContents(XMLTools.java:282)
at com.rapidminer.tools.documentation.OperatorDocumentation.<init>(OperatorDocumentation.java:52)
at com.rapidminer.tools.documentation.XMLOperatorDocBundle.<init>(XMLOperatorDocBundle.java:137)
at com.rapidminer.tools.documentation.XMLOperatorDocBundle$XMLControl.newBundle(XMLOperatorDocBundle.java:89)
at java.util.ResourceBundle.loadBundle(ResourceBundle.java:1501)
at java.util.ResourceBundle.findBundle(ResourceBundle.java:1465)
at java.util.ResourceBundle.findBundle(ResourceBundle.java:1419)
at java.util.ResourceBundle.getBundleImpl(ResourceBundle.java:1361)
... 11 more
Exception in thread "main" java.lang.AbstractMethodError: org.apache.xerces.dom.DeferredElementImpl.getTextContent()Ljava/lang/String;
at com.rapidminer.io.process.conditions.ParameterEqualsCondition.<init>(ParameterEqualsCondition.java:29)
at com.rapidminer.io.process.conditions.ParameterUnequalsCondition.<init>(ParameterUnequalsCondition.java:18)
at com.rapidminer.io.process.rules.AbstractConditionedParseRule.parseCondition(AbstractConditionedParseRule.java:56)
at com.rapidminer.io.process.rules.AbstractConditionedParseRule.<init>(AbstractConditionedParseRule.java:41)
at com.rapidminer.io.process.rules.SetParameterRule.<init>(SetParameterRule.java:27)
at com.rapidminer.io.process.XMLImporter.constructRuleFromElement(XMLImporter.java:186)
at com.rapidminer.io.process.XMLImporter.importParseRules(XMLImporter.java:157)
at com.rapidminer.io.process.XMLImporter.init(XMLImporter.java:107)
at com.rapidminer.RapidMiner.init(RapidMiner.java:644)
I also cant find a .log file anywhere to post whats inside it sorry about that but its nowhere to be found (by me anyway)
any help into this problem would be greatly appreciated thanks
