Hi!
I'm wondering if anyone could share some insight into this problem. I'm trying to run an evolutionary search of parameters for the mentioned operator, but it won't converge.
I've been trying to find out why, but ran into some trouble pinning it down. Take the sonar data example proposed by the logistic regression operator:
<process version="5.3.015">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Sonar" width="90" x="380" y="120">
<parameter key="repository_entry" value="//Samples/data/Sonar"/>
<operator activated="true" class="split_validation" compatibility="5.3.015" expanded="true" height="112" name="Validation" width="90" x="514" y="120">
<operator activated="true" class="logistic_regression" compatibility="5.3.015" expanded="true" height="94" name="Logistic Regression" width="90" x="112" y="30">
<parameter key="kernel_type" value="polynomial"/>
<parameter key="kernel_degree" value="12.0"/>
<connect from_port="training" to_op="Logistic Regression" to_port="training set"/>
<connect from_op="Logistic Regression" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.3.015" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<operator activated="true" class="performance" compatibility="5.3.015" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_op="Sonar" from_port="output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_port="result 1"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 2"/>
<portSpacing port="sink_result 1" spacing="90"/>
<portSpacing port="sink_result 2" spacing="18"/>
</process>
</process>
1) I simply changed to polynomial and set degree at 12. This runs instantly on my PC, but when changing degree to 13, it won't converge not even past 5 minutes.
2) Then I changed max iterations to 1 and started going up. 291 max iterations runs fine, again, almost instantly. 292 max iterations, one minute going already... won't converge.
I'm not a doctor in machine learning algorithms but this looks like a bug to me ;D...
Any ideas of how to cope with this while it gets fixed?
Thanks! I hope the bug report helps.
