Xpath and Strange Behaviour
mmarag
mmarag New Altair Community Member
edited November 2024 in Altair RapidMiner
Dear all,
i have been trying to use Extract Information with Xpath in Rapidminer, in order to extract the title and the content of an article.
Although Google Chrome provides an easy to use tool for obtaining the XPATH, rapidminer is extremely difficult to adjust when it comes to XPATH.
In the process below, i had to include 2 non obvious namespace IDs in order to extract what i needed. Could one please explain why is it so difficult to adopt standard Xpath approaches that run without problems in Google SpreadSheets or in Java and c# XML API?
Thank you in advance
<process version="5.3.015">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
    <process expanded="true">
      <operator activated="true" class="web:process_web" compatibility="5.3.001" expanded="true" height="60" name="Process Documents from Web" width="90" x="45" y="300">
        <parameter key="url" value="http://www.enikos.gr/sports/"/>
        <list key="crawling_rules">
          <parameter key="store_with_matching_url" value=".+sports/.[0-9].+"/>
          <parameter key="follow_link_with_matching_url" value=".+sports/.[0-9].+"/>
        </list>
        <parameter key="max_pages" value="20"/>
        <parameter key="max_depth" value="1"/>
        <parameter key="domain" value="server"/>
        <parameter key="delay" value="2000"/>
        <parameter key="max_threads" value="4"/>
        <parameter key="max_page_size" value="1000"/>
          <operator activated="true" class="text:extract_information" compatibility="5.3.002" expanded="true" height="60" name="Extract Information" width="90" x="179" y="165">
            <parameter key="query_type" value="XPath"/>
            <list key="string_machting_queries"/>
            <list key="regular_expression_queries"/>
            <list key="regular_region_queries"/>
            <list key="xpath_queries">
              <parameter key="title" value="//h:div[contains(@class,'title')]/h:h2/text()"/>
              <parameter key="text" value="concat(  //h:div[contains(@class,'text')]/h:p[1]/text(),  //h:div[contains(@class,'text')]/h:p[2]/text(),  //h:div[contains(@class,'text')]/h:p[3]/text(),  //h:div[contains(@class,'text')]/h:p[4]/text(), //h:div[contains(@class,'text')]/h:p[5]/text(), //h:div[contains(@class,'text')]/h:p[6]/text() )"/>
            </list>
            <list key="namespaces">
              <parameter key="title" value="&lt;h2 xmlns=&quot;http://www.w3.org/1999/xhtml&quot;&gt;&lt;/h2&gt; "/>
              <parameter key="text" value="&lt;p xmlns=&quot;http://www.w3.org/1999/xhtml&quot;&gt;&lt;/p&gt; "/>
            </list>
            <list key="index_queries"/>
          <connect from_port="document" to_op="Extract Information" to_port="document"/>
          <connect from_op="Extract Information" from_port="document" to_port="document 1"/>
        </process>
      <connect from_op="Process Documents from Web" from_port="example set" to_port="result 1"/>
    </process>
</process>
Welcome!
Welcome!
