Its been a week working with RapidMiner Studio 5.3 and I have yet to successfully process text files with FP-Growth and Create Association operators. I even tried a one-page text document and it continuously processes without stopping, then it will freeze up. Sometimes it will generate a
"Process Failed" message. What am I doing wrong? I'm running RapidMiner on a
OS X 10.8.5, 2.3 GHz Intel Core i7, 8G RAM My code is below:
<process version="5.3.015">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="loop_files" compatibility="5.3.015" expanded="true" height="76" name="Loop Files" width="90" x="45" y="75">
<parameter key="directory" value="/Users/ddavis/Desktop/Emotion"/>
<operator activated="true" class="text:read_document" compatibility="5.3.002" expanded="true" height="60" name="Read Document" width="90" x="112" y="75"/>
<connect from_port="file object" to_op="Read Document" to_port="file"/>
<connect from_op="Read Document" from_port="output" to_port="out 1"/>
<portSpacing port="source_file object" spacing="0"/>
<portSpacing port="source_in 2" spacing="0"/>
</process>
<operator activated="true" class="text:process_documents" compatibility="5.3.002" expanded="true" height="94" name="Process Documents" width="90" x="246" y="210">
<parameter key="vector_creation" value="Binary Term Occurrences"/>
<parameter key="prune_below_absolute" value="1"/>
<parameter key="prune_above_absolute" value="999"/>
<operator activated="true" class="text:transform_cases" compatibility="5.3.002" expanded="true" height="60" name="Transform Cases" width="90" x="45" y="120"/>
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize" width="90" x="179" y="210"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="313" y="120"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="447" y="210">
<parameter key="min_chars" value="2"/>
<parameter key="max_chars" value="9999"/>
<operator activated="true" class="text:stem_snowball" compatibility="5.3.002" expanded="true" height="60" name="Stem (Snowball)" width="90" x="648" y="120"/>
<connect from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Stem (Snowball)" to_port="document"/>
<connect from_op="Stem (Snowball)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="numerical_to_binominal" compatibility="5.3.015" expanded="true" height="76" name="Numerical to Binominal" width="90" x="447" y="120"/>
<operator activated="true" class="fp_growth" compatibility="5.3.015" expanded="true" height="76" name="FP-Growth" width="90" x="581" y="255"/>
<operator activated="true" class="create_association_rules" compatibility="5.3.015" expanded="true" height="76" name="Create Association Rules" width="90" x="782" y="120"/>
<connect from_port="input 1" to_op="Loop Files" to_port="in 1"/>
<connect from_op="Loop Files" from_port="out 1" to_op="Process Documents" to_port="documents 1"/>
<connect from_op="Process Documents" from_port="example set" to_op="Numerical to Binominal" to_port="example set input"/>
<connect from_op="Numerical to Binominal" from_port="example set output" to_op="FP-Growth" to_port="example set"/>
<connect from_op="FP-Growth" from_port="frequent sets" to_op="Create Association Rules" to_port="item sets"/>
<connect from_op="Create Association Rules" from_port="rules" to_port="result 1"/>
</process>
</process>
I found two tutorials on YouTube both of which do a similar process but with success.
https://www.youtube.com/watch?v=HBrYuV8eWjchttps://www.youtube.com/watch?v=oXrUz5CWM4EThere are similar issue I have read (
http://rapid-i.com/rapidforum/index.php/topic,7572.0.html,
http://rapid-i.com/rapidforum/index.php/topic,7541.0.html)
