[SOLVED] Problem seeing GUI
I have been using RapidMiner since last two years in my school projects. Recently, I had an issue which I cannot see GUI where i define my algorithm/process. Instead of GUI, I am seeing the below text.
The version I use 5.3.012
How I can fix it?
Is there any way to update any missing files without removing all
Synopsis
The root operator which is the outer most operator of every process.
Each process must contain exactly one operator of this class, and it must be the root operator of the process. This operator provides a set of parameters that are of global relevance to the process like logging and initialization of parameters of the random number generator.
Input
Output
logverbosity: Log verbosity level. Range: all, io, status, init, notes, warning, error, fatal, almost_none, off; default: init
logfile: File to write logging information to. Range: filename
resultfile: File to write inputs of the ResultWriter operators to. Range: filename
random seed: Global random seed for random generators (-1 for initialization by system time). Range: integer; -2147483648-+?; default: 2001
send mail: Send email upon completion of the process. Range: always, never, for_long_processes; default: never
notification email: Email address for the notification mail. Range: string
process duration for mail: Minimum process duration to send emails (in minutes). Range: integer; 0-+?; default: 30
encoding: The encoding used for reading or writing files. Range: SYSTEM, Big5, Big5-HKSCS, EUC-JP, EUC-KR, GB18030, GB2312, GBK, IBM-Thai, IBM00858, IBM01140, IBM01141, IBM01142, IBM01143, IBM01144, IBM01145, IBM01146, IBM01147, IBM01148, IBM01149, IBM037, IBM1026, IBM1047, IBM273, IBM277, IBM278, IBM280, IBM284, IBM285, IBM297, IBM420, IBM424, IBM437, IBM500, IBM775, IBM850, IBM852, IBM855, IBM857, IBM860, IBM861, IBM862, IBM863, IBM864, IBM865, IBM866, IBM868, IBM869, IBM870, IBM871, IBM918, ISO-2022-CN, ISO-2022-JP, ISO-2022-JP-2, ISO-2022-KR, ISO-8859-1, ISO-8859-13, ISO-8859-15, ISO-8859-2, ISO-8859-3, ISO-8859-4, ISO-8859-5, ISO-8859-6, ISO-8859-7, ISO-8859-8, ISO-8859-9, JIS_X0201, JIS_X0212-1990, KOI8-R, KOI8-U, Shift_JIS, TIS-620, US-ASCII, UTF-16, UTF-16BE, UTF-16LE, UTF-32, UTF-32BE, UTF-32LE, UTF-8, windows-1250, windows-1251, windows-1252, windows-1253, windows-1254, windows-1255, windows-1256, windows-1257, windows-1258, windows-31j, x-Big5-Solaris, x-euc-jp-linux, x-EUC-TW, x-eucJP-Open, x-IBM1006, x-IBM1025, x-IBM1046, x-IBM1097, x-IBM1098, x-IBM1112, x-IBM1122, x-IBM1123, x-IBM1124, x-IBM1381, x-IBM1383, x-IBM33722, x-IBM737, x-IBM834, x-IBM856, x-IBM874, x-IBM875, x-IBM921, x-IBM922, x-IBM930, x-IBM933, x-IBM935, x-IBM937, x-IBM939, x-IBM942, x-IBM942C, x-IBM943, x-IBM943C, x-IBM948, x-IBM949, x-IBM949C, x-IBM950, x-IBM964, x-IBM970, x-ISCII91, x-ISO-2022-CN-CNS, x-ISO-2022-CN-GB, x-iso-8859-11, x-JIS0208, x-JISAutoDetect, x-Johab, x-MacArabic, x-MacCentralEurope, x-MacCroatian, x-MacCyrillic, x-MacDingbat, x-MacGreek, x-MacHebrew, x-MacIceland, x-MacRoman, x-MacRomania, x-MacSymbol, x-MacThai, x-MacTurkish, x-MacUkraine, x-MS932_0213, x-MS950-HKSCS, x-mswin-936, x-PCK, x-SJIS_0213, x-UTF-16LE-BOM, X-UTF-32BE-BOM, X-UTF-32LE-BOM, x-windows-50220, x-windows-50221, x-windows-874, x-windows-949, x-windows-950, x-windows-iso2022jp; default: 'SYSTEM'
