I have been working on developing a sentiment classifier using Linear SVM in RapidMiner.
I use the data found at
http://snap.stanford.edu/data/web-Amazon.html as my training set.
The dataset I use is very large - about 78,000 positive and negative reviews.
When I run this process,it has taken over 13 hours and still continuing!(in the Validation stage currently)!
So,my query is whether this duration is acceptable or is there any way to optimise the classifier? What is the estimated time for datasets of such size?
Here is the XML code:
<process version="5.3.013">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="text:process_document_from_file" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="30">
<list key="text_directories">
<parameter key="negative" value="C:\Users\Keshav\Documents\Academics\Project\train\neg"/>
<parameter key="positive" value="C:\Users\Keshav\Documents\Academics\Project\train\pos"/>
</list>
<parameter key="prune_method" value="percentual"/>
<parameter key="prune_above_percent" value="95.0"/>
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize" width="90" x="112" y="75"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="216" y="162"/>
<operator activated="true" class="text:stem_porter" compatibility="5.3.002" expanded="true" height="60" name="Stem (Porter)" width="90" x="292" y="247"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="421" y="338"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Stem (Porter)" to_port="document"/>
<connect from_op="Stem (Porter)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="x_validation" compatibility="5.3.013" expanded="true" height="112" name="Validation" width="90" x="313" y="165">
<operator activated="true" class="support_vector_machine_linear" compatibility="5.3.013" expanded="true" height="76" name="SVM (Linear)" width="90" x="112" y="30"/>
<connect from_port="training" to_op="SVM (Linear)" to_port="training set"/>
<connect from_op="SVM (Linear)" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.3.013" expanded="true" height="76" name="Apply Model" width="90" x="51" y="56">
<operator activated="true" class="performance" compatibility="5.3.013" expanded="true" height="76" name="Performance" width="90" x="99" y="165"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<operator activated="true" class="store" compatibility="5.3.013" expanded="true" height="60" name="Store (2)" width="90" x="380" y="30">
<parameter key="repository_entry" value="//Local Repository/data2"/>
<operator activated="true" class="store" compatibility="5.3.013" expanded="true" height="60" name="Store" width="90" x="45" y="210">
<parameter key="repository_entry" value="//Local Repository/data1"/>
<connect from_op="Process Documents from Files" from_port="example set" to_op="Validation" to_port="training"/>
<connect from_op="Process Documents from Files" from_port="word list" to_op="Store" to_port="input"/>
<connect from_op="Validation" from_port="model" to_op="Store (2)" to_port="input"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 2"/>
<connect from_op="Store (2)" from_port="through" to_port="result 1"/>
</process>
</process>
Hoping to find a solution to this problem.
Thanks,
Keshav
