[SOLVED] Has RM concept of metadata associated to ExampleSet, not attribute?
Hello all,
In RM is there concept of metadata associated to ExampleSet (not to attribute)?
For example, I have conducted an experiment on three subjects "Joe", "Jane", "Fred", and there are three datafiles that have the same format, but different content. I have a file reader that converts each file to an ExampleSet.
So after I load the files into RM, I have exampleSet1 from experiment1, exampleSet2 from experiment2, exampleSet3 from experiment3 and so on.
What RM abstraction helps me associate "Joe" to exampleSet1 , "Jane" to examplSet2 etc.?
I suppose I could add another attribute "Subject Name" to the exampleSet, but then I have a strange sparsity situation.
I might have 1e5 examples with numerical data and "Subject Name" not set.
And one example with no numerical data, and "Subject Name" set.
Is this the right way to go about it?
In the end result, I suppose, this metadata might be used for labelling charts and plots. E.g. blue curve is "Fred", red curve is "Joe" etc.
Thank you for your advice.
Owen
