did you implement it? now i have the same problem. i have multilpl output nodes
@marius_Helf wrote:Hi, if the three columns are really three different target variables, then you have to create three different Neural Nets and set the respective column as label.Best regards,Marius
You probably want to ping @Carlos or @MariusHelf!
