<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="Create Document" width="90" x="45" y="30"> <parameter key="text" value="AFTER USING APPLE FOR MORE THAN 2 YEARS, I WAS HESISTANT TO SWITCH TO ANDROID, NO PHONE IN THE MARKET COULD TEMPT ME EXCEPT THIS ONE . "/> </operator> <operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="Create Document (3)" width="90" x="45" y="120"> <parameter key="text" value="DISPLAY IS FANTASTIC, CAMERA PERFORMANCE IS CLASS APART, MOTION SENSORS ARE AMAZING AND SMART ENOUGH, BATTERY LIFE IS REALLY REALLY GOOD . "/> </operator> <operator activated="true" class="text:create_document" compatibility="5.3.002" expanded="true" height="60" name="Create Document (4)" width="90" x="45" y="210"> <parameter key="text" value="STYLISH.WITH FLIP COVER AND GOOD BATTERY BACKUP THEN THIS IS THE BEST PHONE . "/> </operator> <operator activated="true" class="collect" compatibility="6.0.002" expanded="true" height="112" name="Collect" width="90" x="246" y="30"/> <operator activated="true" class="loop_collection" compatibility="6.0.002" expanded="true" height="76" name="Loop Collection" width="90" x="246" y="165"> <process expanded="true"> <operator activated="true" class="text:keep_document_parts" compatibility="5.3.002" expanded="true" height="60" name="Keep Document Parts (3)" width="90" x="45" y="30"> <parameter key="extraction_regex" value="[\sA-Z0-9]+(BATTERY)[\sA-Z0-9']+|[.,]?\s?(BATTERY)[,]?[\sA-Z0-9']+"/> </operator> <operator activated="true" class="text:documents_to_data" compatibility="5.3.002" expanded="true" height="76" name="Documents to Data" width="90" x="313" y="30"> <parameter key="text_attribute" value="textOfDocument"/> </operator> <connect from_port="single" to_op="Keep Document Parts (3)" to_port="document"/> <connect from_op="Keep Document Parts (3)" from_port="document" to_op="Documents to Data" to_port="documents 1"/> <connect from_op="Documents to Data" from_port="example set" to_port="output 1"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="6.0.002" expanded="true" height="76" name="Append" width="90" x="45" y="345"/> <operator activated="true" class="text:process_document_from_data" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Data" width="90" x="246" y="345"> <parameter key="vector_creation" value="Term Occurrences"/> <parameter key="keep_text" value="true"/> <list key="specify_weights"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize" width="90" x="112" y="30"/> <operator activated="true" class="text:filter_documents_by_content" compatibility="5.3.002" expanded="true" height="76" name="Filter Documents (2)" width="90" x="246" y="30"> <parameter key="string" value="battery"/> </operator> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Filter Documents (2)" to_port="documents 1"/> <connect from_op="Filter Documents (2)" from_port="documents" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Create Document" from_port="output" to_op="Collect" to_port="input 1"/> <connect from_op="Create Document (3)" from_port="output" to_op="Collect" to_port="input 2"/> <connect from_op="Create Document (4)" from_port="output" to_op="Collect" to_port="input 3"/> <connect from_op="Collect" from_port="collection" to_op="Loop Collection" to_port="collection"/> <connect from_op="Loop Collection" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
