<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.1.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="7.1.000" expanded="true" height="68" name="Retrieve t123_product_words" width="90" x="112" y="85"> <parameter key="repository_entry" value="//Local Repository/data/t123_product_words"/> </operator> <operator activated="true" class="sample_stratified" compatibility="7.1.000" expanded="true" height="82" name="Sample (Stratified)" width="90" x="246" y="85"/> <operator activated="true" breakpoints="after" class="loop_values" compatibility="7.1.000" expanded="true" height="82" name="Loop Values" width="90" x="380" y="85"> <parameter key="attribute" value="word"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="7.1.000" expanded="true" height="68" name="Retrieve synonyms_all" width="90" x="179" y="85"> <parameter key="repository_entry" value="//Local Repository/data/synonyms_all"/> </operator> <operator activated="true" class="generate_attributes" compatibility="7.1.000" expanded="true" height="82" name="Generate Attributes" width="90" x="514" y="136"> <list key="function_descriptions"> <parameter key="contains_attribute" value="if(contains(att1,%{loop_value}),att1,"NOMATCH")"/> </list> </operator> <connect from_op="Retrieve synonyms_all" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="out 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="7.1.000" expanded="true" height="82" name="Append" width="90" x="514" y="85"/> <operator activated="true" class="remove_duplicates" compatibility="7.1.000" expanded="true" height="82" name="Remove Duplicates" width="90" x="648" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="contains_attribute"/> </operator> <operator activated="true" class="filter_examples" compatibility="7.1.000" expanded="true" height="103" name="Filter Examples" width="90" x="782" y="85"> <list key="filters_list"> <parameter key="filters_entry_key" value="contains_attribute.does_not_equal.NOMATCH"/> </list> </operator> <connect from_op="Retrieve t123_product_words" from_port="output" to_op="Sample (Stratified)" to_port="example set input"/> <connect from_op="Sample (Stratified)" from_port="example set output" to_op="Loop Values" to_port="example set"/> <connect from_op="Loop Values" from_port="out 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_op="Remove Duplicates" to_port="example set input"/> <connect from_op="Remove Duplicates" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.1.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.1.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="7.1.001" expanded="true" height="68" name="Retrieve t123_product_words" width="90" x="112" y="85"> <parameter key="repository_entry" value="//Local Repository/data/t123_product_words"/> </operator> <operator activated="true" breakpoints="after" class="loop_values" compatibility="7.1.001" expanded="true" height="82" name="Loop Values" width="90" x="380" y="85"> <parameter key="attribute" value="word"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="7.1.001" expanded="true" height="68" name="Retrieve synonyms_all_lowercase_splitted_trimmed" width="90" x="313" y="85"> <parameter key="repository_entry" value="../data/synonyms_all_lowercase_splitted_trimmed"/> </operator> <operator activated="true" class="generate_attributes" compatibility="7.1.001" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="648" y="136"> <list key="function_descriptions"> <parameter key="searched_word" value="trim(%{loop_value})"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="7.1.001" expanded="true" height="82" name="Generate Attributes" width="90" x="782" y="136"> <list key="function_descriptions"> <parameter key="contains_attribute" value="if([word_1]==[searched_word]||[word_2]==[searched_word]||[word_3]==[searched_word]||[word_4]==[searched_word]||[word_5]==[searched_word]||[word_6]==[searched_word]||[word_7]==[searched_word]||[word_8]==[searched_word]||[word_9]==[searched_word]||[word_10]==[searched_word]||[word_11]==[searched_word]||[word_12]==[searched_word]||[word_13]==[searched_word]||[word_14]==[searched_word]||[word_15]==[searched_word]||[word_16]==[searched_word]||[word_17]==[searched_word]||[word_18]==[searched_word]||[word_19]==[searched_word]||[word_20]==[searched_word]||[word_21]==[searched_word]||[word_22]==[searched_word]||[word_23]==[searched_word]||[word_24]==[searched_word]||[word_25]==[searched_word]||[word_26]==[searched_word]||[word_27]==[searched_word]||[word_28]==[searched_word]||[word_29]==[searched_word]||[word_30]==[searched_word]||[word_31]==[searched_word]||[word_32]==[searched_word]||[word_33]==[searched_word]||[word_34]==[searched_word]||[word_35]==[searched_word]||[word_36]==[searched_word]||[word_37]==[searched_word]||[word_38]==[searched_word]||[word_39]==[searched_word]||[word_40]==[searched_word]||[word_41]==[searched_word]||[word_42]==[searched_word]||[word_43]==[searched_word]||[word_44]==[searched_word]||[word_45]==[searched_word]||[word_46]==[searched_word]||[word_47]==[searched_word]||[word_48]==[searched_word]||[word_49]==[searched_word]||[word_50]==[searched_word]||[word_51]==[searched_word]||[word_52]==[searched_word]||[word_53]==[searched_word]||[word_54]==[searched_word]||[word_55]==[searched_word]||[word_56]==[searched_word]||[word_57]==[searched_word]||[word_58]==[searched_word]||[word_59]==[searched_word]||[word_60]==[searched_word]||[word_61]==[searched_word]||[word_62]==[searched_word]||[word_63]==[searched_word]||[word_64]==[searched_word]||[word_65]==[searched_word]||[word_66]==[searched_word]||[word_67]==[searched_word]||[word_68]==[searched_word]||[word_69]==[searched_word]||[word_70]==[searched_word]||[word_71]==[searched_word]||[word_72]==[searched_word]||[word_73]==[searched_word]||[word_74]==[searched_word]||[word_75]==[searched_word]||[word_76]==[searched_word]||[word_77]==[searched_word]||[word_78]==[searched_word]||[word_79]==[searched_word]||[word_80]==[searched_word]||[word_81]==[searched_word]||[word_82]==[searched_word]||[word_83]==[searched_word]||[word_84]==[searched_word]||[word_85]==[searched_word]||[word_86]==[searched_word]||[word_87]==[searched_word]||[word_88]==[searched_word]||[word_89]==[searched_word]||[word_90]==[searched_word],"YES","NO")"/> </list> </operator> <connect from_op="Retrieve synonyms_all_lowercase_splitted_trimmed" from_port="output" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="out 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="7.1.001" expanded="true" height="82" name="Append" width="90" x="514" y="85"/> <operator activated="true" class="filter_examples" compatibility="7.1.001" expanded="true" height="103" name="Filter Examples" width="90" x="782" y="85"> <list key="filters_list"> <parameter key="filters_entry_key" value="contains_attribute.does_not_equal.YES"/> </list> </operator> <operator activated="true" class="store" compatibility="7.1.001" expanded="true" height="68" name="Store" width="90" x="983" y="85"> <parameter key="repository_entry" value="//Local Repository/data/t123_synonyms_processed"/> </operator> <connect from_op="Retrieve t123_product_words" from_port="output" to_op="Loop Values" to_port="example set"/> <connect from_op="Loop Values" from_port="out 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Store" to_port="input"/> <connect from_op="Store" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
