Hi Scott,
unfortunately the Branding does only allow you to change the CSS Layout of a server page to my knowledge. Neither favicon nor webpage title are part of the layout of a page and can't be changed by CSS.
However, there might be two worarkounds that can be of help:
1. You can use a custom Java Script function within your Web Apps to replace it. While easy, the downside is that it will only be applicable AFTER the user has successfully logged in.
2. One might use the Deployment Overlays of JBoss to replace the favicon file that RapidMiner uses with your own. However, this will only work with considerable effort for the page title, as this would need to be replaced within the html template files of the server.
Greetings,
Sebastian
Whilst there's no way in the app it is possible to edit the branding overall.
Please note: I have not checked fully if this breaks any licence agreements so please check with your friendly local RapidMiner rep if using in production. I just wanted to demonstrate that it's possible. :smileytongue:
Hi Edward,
interesting solution. Did you by chance try to combine that with JBoss Overlays so that changes (might) survive updates of the RapidMiner ear? Do you know if that works now? I once tried and it didn't work due to a bug in JBoss, but perhaps there is now a more current version that solved it.
I haven't tried with JBOSS overlays, I just manually unzipped & edited the files about 30 minutes ago for giggles
You are correct, my changes wouldn't survive ear updates. :smileywink:
John
RapidMiner China
RapidMiner Consulting, Sales & Training in China - www.rapidminerchina.com
