Hi, I must solve a thermal staedy state problem (refer to attached figure).
I ve all three types of heat treansfer mode.
Can help me to set this analysis ?
Thank you.
Hi @Fabiano.Pagliarini
Did you see Input data for thermal analysis on OptiStruct help?
thank you @Prakash Pagadala. I ve solved.
I ve just a question.
How to set the boundary conditions for radiation ?
This is under development and should be available soon.
thank you so much for your support.
ok
After a staedy state analysis i ve the contours of grid temperatures and element flux (W/mm^2).
How can I get the heat (W) ?
There is a possibility to set a flag on CONTROL CARD: GLOBAL OUTPUT REQUEST?
HI,
I don't see a way to get W directly.
As a workaround, calculate the area from HyperMesh and multiply total element flux to get in W
