<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <parameter key="parallelize_main_process" value="true"/> <process expanded="true"> <operator activated="true" class="text:process_document_from_data" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Data" width="90" x="45" y="30"> <parameter key="prune_above_percent" value="95.0"/> <parameter key="prune_below_absolute" value="20"/> <parameter key="prune_above_absolute" value="200"/> <parameter key="prune_below_rank" value="0.25"/> <parameter key="prune_above_rank" value="0.75"/> <list key="specify_weights"/> <parameter key="parallelize_vector_creation" value="true"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/> <operator activated="true" class="text:transform_cases" compatibility="5.3.002" expanded="true" height="60" name="Transform Cases" width="90" x="179" y="30"/> <operator activated="true" class="text:stem_porter" compatibility="5.3.002" expanded="true" height="60" name="Stem (Porter)" width="90" x="313" y="30"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="447" y="30"/> <operator activated="true" class="text:filter_by_length" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="648" y="30"> <parameter key="max_chars" value="100"/> </operator> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Stem (Porter)" to_port="document"/> <connect from_op="Stem (Porter)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="multiply" compatibility="6.0.002" expanded="true" height="94" name="Multiply" width="90" x="246" y="120"/> <operator activated="true" class="set_role" compatibility="5.3.013" expanded="true" height="76" name="Set Role" width="90" x="447" y="30"> <parameter key="attribute_name" value="Sentiment"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"> <parameter key="ID" value="id"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="6.0.002" expanded="true" height="76" name="Select Attributes" width="90" x="581" y="30"> <parameter key="attribute_filter_type" value="no_missing_values"/> <parameter key="attribute" value="text"/> </operator> <operator activated="true" class="optimize_parameters_grid" compatibility="6.0.002" expanded="true" height="112" name="Optimize Parameters (Grid)" width="90" x="715" y="30"> <list key="parameters"> <parameter key="SVM (Linear).C" value="[1e-6;1;6;logarithmic]"/> </list> <parameter key="parallelize_optimization_process" value="true"/> <process expanded="true"> <operator activated="true" class="x_validation" compatibility="6.0.002" expanded="true" height="112" name="Validation" width="90" x="45" y="30"> <parameter key="number_of_validations" value="5"/> <parameter key="parallelize_training" value="true"/> <parameter key="parallelize_testing" value="true"/> <process expanded="true"> <operator activated="true" class="nominal_to_binominal" compatibility="6.0.002" expanded="true" height="94" name="Nominal to Binominal" width="90" x="45" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Sentiment"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="support_vector_machine_linear" compatibility="6.0.002" expanded="true" height="76" name="SVM (Linear)" width="90" x="179" y="30"> <parameter key="kernel_cache" value="1000"/> <parameter key="C" value="10.0"/> </operator> <connect from_port="training" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_op="SVM (Linear)" to_port="training set"/> <connect from_op="SVM (Linear)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="6.0.002" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="6.0.002" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="6.0.002" expanded="true" height="76" name="Log" width="90" x="246" y="75"> <list key="log"> <parameter key="C" value="operator.SVM (Linear).parameter.C"/> <parameter key="Performance" value="operator.Validation.value.performance"/> </list> </operator> <connect from_port="input 1" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> <connect from_op="Process Documents from Data" from_port="example set" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_port="result 4"/> <connect from_op="Multiply" from_port="output 2" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Optimize Parameters (Grid)" to_port="input 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="parameter" to_port="result 2"/> <connect from_op="Optimize Parameters (Grid)" from_port="result 1" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="126"/> <portSpacing port="sink_result 5" spacing="0"/> </process> </operator></process>
