I am using the information selection extension package for noise in label detection. The targets of my problem are numerical numbers. I am trying to use CNN but it does not select any examples. Does the package support regression as well or is it strictly for classification. If it also supports regression, what parameters are needed to set the process up correctly?
<process version="7.1.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.1.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" breakpoints="after" class="read_csv" compatibility="7.1.000" expanded="true" height="68" name="Read CSV" width="90" x="45" y="34">
<parameter key="csv_file" value="/Users/xinkwang/test_file.csv"/>
<parameter key="column_separators" value=","/>
<parameter key="use_quotes" value="false"/>
<list key="annotations"/>
<list key="data_set_meta_data_information"/>
<parameter key="read_not_matching_values_as_missings" value="false"/>
<operator activated="true" class="set_role" compatibility="7.1.000" expanded="true" height="82" name="Set Role" width="90" x="179" y="34">
<parameter key="attribute_name" value="att324"/>
<list key="set_additional_roles">
<parameter key="asin" value="id"/>
<parameter key="product_name" value="id"/>
</list>
<operator activated="true" breakpoints="after" class="select_attributes" compatibility="7.1.000" expanded="true" height="82" name="Select Attributes" width="90" x="313" y="34">
<parameter key="attributes" value="product_name|asin"/>
<operator activated="true" class="prules:cnn_sel" compatibility="7.0.000" expanded="true" height="103" name="Select by CNN" width="90" x="447" y="34">
<parameter key="measure_types" value="NumericalMeasures"/>
<connect from_op="Read CSV" from_port="output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Select by CNN" to_port="exampleSet"/>
<connect from_op="Select by CNN" from_port="exampleSet" to_port="result 1"/>
<connect from_op="Select by CNN" from_port="prototypes" to_port="result 2"/>
</process>
</process>
