[SOLVED] RM 5.3 community edition - Which hardware is supported?
ighyboo
New Altair Community Member
Dear all,
I've been playing around with RM for a bit now and I would like to upgrade my machine in order to speed up a bit the various analysis I'm performing.
It is fairly clear in the commercial version what are the limits in terms of handling multiple processors, amount of RAM, DBs, file formats, etc.
What is not clear to me is what's supported in the Community Edition
I was thinking of a second hand server with the following specs:
2x Xeon QuadCore (8 cores, potentially 16 threads if I'm lucky to find a Hyper-Threading enabled CPU)
8/16 GB Ram
Windows 7 64bit
Would that make sense?
Or is the community edition only capable of handling a certain amount of Cores/RAM?
If so, what are the limits?
Thanks a lot in advance
8/16 GB Ram
Windows 7 64bit
the community edition, i.e. RapidMiner 5, is capable of handling an unlimited amount of hardware resources. For optimal usage it is best combined with a RapidMiner Server (formerly RapidAnalytics) which can be used to e.g. calculate several processes at the same time. It can also be installed on the same machine are accessed via the network. That way you could prepare your processes in RapidMiner Studio on your laptop and run them on the Server.
Best regards,
Marius0 -
Thanks a lot Marius
Maybe once I have put some more experience under the belt and start my own data-consultancy business I'll think about investing in a similar setup..
At the moment a second hand server (the HW flavour) will have to do..
0 -
the RapidMiner Server is a piece of software that also has a community edition available on our website - no need for a new hardware server
Best regards,
Marius0 -
I see.... 8)
Thanks a lot Marius! Always extremely helpful!!0
