Hi, I must perfom a Frequency Response Analysis.
In particular i've a pressurized cylinder subject to a Impulse load with frequency of 1 Hz and magnitude 0 - 3000 psi - 0 (sin function load).
i want the response on first 5 natural modal frequency.
how i must set the analysis ?
Thank you
You can perform frequency response (modal) where you can call for first five modal frequencies and perform frequency response over it. You can refer tutorials for the same in the help file.
