"Installation RapidMiner-Server-CE-1.315.ear"
alessiotempiett
New Altair Community Member
I'm trying to install RapidMiner-Server-CE-1.3.015.ear on my machine.
I put my ear on jboss-5.1.0.GA but it don't start and on my server.log apper this error:
Thanks
Can you help me?
Deployment "vfszip:/usr/local/jboss-5.1.0.GA/server/default/deploy/RapidMiner-Server-CE-1.3.015.ear/" is in error due to the following reason(s): java.lang.IllegalStateException: Failed to find ContainerDependencyMetaData for interface: de.rapidanalytics.ejb.service.ServiceDataSourceRegistry
at org.jboss.deployers.plugins.deployers.DeployersImpl.checkComplete(DeployersImpl.java:993)
at org.jboss.deployers.plugins.deployers.DeployersImpl.checkComplete(DeployersImpl.java:939)
at org.jboss.deployers.plugins.main.MainDeployerImpl.checkComplete(MainDeployerImpl.java:873)
Thanks
we highly recommend to use the installer that comes with the .ear, so you don't need to setup all the bits and bobs of the application server yourself. However if you want to do so, you need JBoss 6.1.0 Final for RM Server 1.3. For RM Server 2.0, you need JBoss EAP 6.1 (aka 7.2) Neither will work with JBoss 5.1.
Marco0 -
I have tried to use the installer but it contains dos script and I run on Mac OSX.
I have downloaded JBoss 6.1.0 Final but I have found theese errors on my log:
Can you help me?
11:30:41,289 ERROR [org.jboss.msc.service.fail] (MSC service thread 1-1) MSC000001: Failed to start service jboss.deployment.subunit."RapidMiner-Server-CE-1.3.015.ear"."RapidAnalytics_War.war".POST_MODULE: org.jboss.msc.service.StartException in service jboss.deployment.subunit."RapidMiner-Server-CE-1.3.015.ear"."RapidAnalytics_War.war".POST_MODULE: JBAS018733: Failed to process phase POST_MODULE of subdeployment "RapidAnalytics_War.war" of deployment "RapidMiner-Server-CE-1.3.015.ear"
at org.jboss.as.server.deployment.DeploymentUnitPhaseService.start(DeploymentUnitPhaseService.java:127) [jboss-as-server-7.2.0.Final-redhat-8.jar:7.2.0.Final-redhat-8]
at org.jboss.msc.service.ServiceControllerImpl$StartTask.startService(ServiceControllerImpl.java:1811) [jboss-msc-1.0.4.GA-redhat-1.jar:1.0.4.GA-redhat-1]
at org.jboss.msc.service.ServiceControllerImpl$StartTask.run(ServiceControllerImpl.java:1746) [jboss-msc-1.0.4.GA-redhat-1.jar:1.0.4.GA-redhat-1]
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895) [classes.jar:1.6.0_51]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918) [classes.jar:1.6.0_51]
at java.lang.Thread.run(Thread.java:680) [classes.jar:1.6.0_51]
Caused by: java.lang.NoClassDefFoundError: org/quartz/SchedulerException
at java.lang.Class.getDeclaredConstructors0(Native Method) [classes.jar:1.6.0_51]
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2437) [classes.jar:1.6.0_51]
at java.lang.Class.getConstructor0(Class.java:2747) [classes.jar:1.6.0_51]
at java.lang.Class.getConstructor(Class.java:1684) [classes.jar:1.6.0_51]
at org.jboss.as.jsf.deployment.JSFManagedBeanProcessor.deploy(JSFManagedBeanProcessor.java:103)
at org.jboss.as.server.deployment.DeploymentUnitPhaseService.start(DeploymentUnitPhaseService.java:120) [jboss-as-server-7.2.0.Final-redhat-8.jar:7.2.0.Final-redhat-8]
... 5 more
Caused by: java.lang.ClassNotFoundException: org.quartz.SchedulerException from [Module "deployment.RapidMiner-Server-CE-1.3.015.ear.RapidAnalytics_War.war:main" from Service Module Loader]
at org.jboss.modules.ModuleClassLoader.findClass(ModuleClassLoader.java:196) [jboss-modules.jar:1.2.0.Final-redhat-1]
at org.jboss.modules.ConcurrentClassLoader.performLoadClassUnchecked(ConcurrentClassLoader.java:444) [jboss-modules.jar:1.2.0.Final-redhat-1]
at org.jboss.modules.ConcurrentClassLoader.performLoadClassChecked(ConcurrentClassLoader.java:432) [jboss-modules.jar:1.2.0.Final-redhat-1]
at org.jboss.modules.ConcurrentClassLoader.performLoadClassChecked(ConcurrentClassLoader.java:399) [jboss-modules.jar:1.2.0.Final-redhat-1]
at org.jboss.modules.ConcurrentClassLoader.performLoadClass(ConcurrentClassLoader.java:374) [jboss-modules.jar:1.2.0.Final-redhat-1]
at org.jboss.modules.ConcurrentClassLoader.loadClass(ConcurrentClassLoader.java:119) [jboss-modules.jar:1.2.0.Final-redhat-1]
... 11 more
11:30:41,575 ERROR [org.jboss.msc.service.fail] (MSC service thread 1-4) MSC000001: Failed to start service jboss.deployment.subunit."RapidMiner-Server-CE-1.3.015.ear"."RapidAnalytics_Service_War.war".POST_MODULE: org.jboss.msc.service.StartException in service jboss.deployment.subunit."RapidMiner-Server-CE-1.3.015.ear"."RapidAnalytics_Service_War.war".POST_MODULE: JBAS018733: Failed to process phase POST_MODULE of subdeployment "RapidAnalytics_Service_War.war" of deployment "RapidMiner-Server-CE-1.3.015.ear"
Caused by: java.lang.RuntimeException: JBAS018757: Error getting reflective information for class de.rapidanalytics.web.service.ProcessService_1_3 with ClassLoader ModuleClassLoader for Module "deployment.RapidMiner-Server-CE-1.3.015.ear.RapidAnalytics_Service_War.war:main" from Service Module Loader
at org.jboss.as.server.deployment.reflect.DeploymentReflectionIndex.getClassIndex(DeploymentReflectionIndex.java:72) [jboss-as-server-7.2.0.Final-redhat-8.jar:7.2.0.Final-redhat-8]
at org.jboss.as.ee.metadata.MethodAnnotationAggregator.runtimeAnnotationInformation(MethodAnnotationAggregator.java:58)
at org.jboss.as.ee.component.deployers.InterceptorAnnotationProcessor.handleAnnotations(InterceptorAnnotationProcessor.java:107)
at org.jboss.as.ee.component.deployers.InterceptorAnnotationProcessor.processComponentConfig(InterceptorAnnotationProcessor.java:92)
at org.jboss.as.ee.component.deployers.InterceptorAnnotationProcessor.deploy(InterceptorAnnotationProcessor.java:77)
... 5 more
at java.lang.Class.getDeclaredFields0(Native Method) [classes.jar:1.6.0_51]
at java.lang.Class.privateGetDeclaredFields(Class.java:2339) [classes.jar:1.6.0_51]
at java.lang.Class.getDeclaredFields(Class.java:1770) [classes.jar:1.6.0_51]
at org.jboss.as.server.deployment.reflect.ClassReflectionIndex.<init>(ClassReflectionIndex.java:57) [jboss-as-server-7.2.0.Final-redhat-8.jar:7.2.0.Final-redhat-8]
at org.jboss.as.server.deployment.reflect.DeploymentReflectionIndex.getClassIndex(DeploymentReflectionIndex.java:68) [jboss-as-server-7.2.0.Final-redhat-8.jar:7.2.0.Final-redhat-8]
... 10 more
Caused by: java.lang.ClassNotFoundException: org.quartz.SchedulerException from [Module "deployment.RapidMiner-Server-CE-1.3.015.ear.RapidAnalytics_Service_War.war:main" from Service Module Loader]
... 15 more
11:30:41,787 ERROR [org.jboss.as.server] (DeploymentScanner-threads - 1) JBAS015870: Deploy of deployment "RapidMiner-Server-CE-1.3.015.ear" was rolled back with the following failure message:
"JBAS014671: Failed services" => {
"jboss.deployment.subunit.\"RapidMiner-Server-CE-1.3.015.ear\".\"RapidAnalytics_Service_War.war\".POST_MODULE" => "org.jboss.msc.service.StartException in service jboss.deployment.subunit.\"RapidMiner-Server-CE-1.3.015.ear\".\"RapidAnalytics_Service_War.war\".POST_MODULE: JBAS018733: Failed to process phase POST_MODULE of subdeployment \"RapidAnalytics_Service_War.war\" of deployment \"RapidMiner-Server-CE-1.3.015.ear\"
Caused by: java.lang.RuntimeException: JBAS018757: Error getting reflective information for class de.rapidanalytics.web.service.ProcessService_1_3 with ClassLoader ModuleClassLoader for Module \"deployment.RapidMiner-Server-CE-1.3.015.ear.RapidAnalytics_Service_War.war:main\" from Service Module Loader
Caused by: java.lang.ClassNotFoundException: org.quartz.SchedulerException from [Module \"deployment.RapidMiner-Server-CE-1.3.015.ear.RapidAnalytics_Service_War.war:main\" from Service Module Loader]",
"jboss.deployment.subunit.\"RapidMiner-Server-CE-1.3.015.ear\".\"RapidAnalytics_War.war\".POST_MODULE" => "org.jboss.msc.service.StartException in service jboss.deployment.subunit.\"RapidMiner-Server-CE-1.3.015.ear\".\"RapidAnalytics_War.war\".POST_MODULE: JBAS018733: Failed to process phase POST_MODULE of subdeployment \"RapidAnalytics_War.war\" of deployment \"RapidMiner-Server-CE-1.3.015.ear\"
Caused by: java.lang.ClassNotFoundException: org.quartz.SchedulerException from [Module \"deployment.RapidMiner-Server-CE-1.3.015.ear.RapidAnalytics_War.war:main\" from Service Module Loader]"
"JBAS014771: Services with missing/unavailable dependencies" => [
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.UserManagementEJBImpl.Validator is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.UserManagementEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.AccessLogEJBImpl.Validator is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.AccessLogEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ProcessJobEJBImpl.ValidatorFactory is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ProcessJobEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.RepositoryEJBImpl.ValidatorFactory is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.RepositoryEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.TriggerEJBImpl.ValidatorFactory is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.TriggerEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ServiceDataSourceRegistry.ValidatorFactory is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ServiceDataSourceRegistry]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.UserCreationEJBImpl.ValidatorFactory is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.UserCreationEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.TriggerManagementEJBImpl.Validator is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.TriggerManagementEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ExportedProcessEJBImpl.Validator is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ExportedProcessEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.SchedulerEJBImpl.Validator is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.SchedulerEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.RapidMinerEJBImpl.ValidatorFactory is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.RapidMinerEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ConfigurationEJBImpl.Validator is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ConfigurationEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.TriggerEJBImpl.Validator is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.TriggerEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ServiceDataSourceRegistry.Validator is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ServiceDataSourceRegistry]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.RapidMinerEJBImpl.Validator is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.RapidMinerEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ProcessHelperEJBImpl.ValidatorFactory is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ProcessHelperEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ConfigurationEJBImpl.ValidatorFactory is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ConfigurationEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.UserCreationEJBImpl.Validator is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.UserCreationEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ExportedProcessEJBImpl.ValidatorFactory is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ExportedProcessEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.UserManagementEJBImpl.ValidatorFactory is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.UserManagementEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.MigrationEJBImpl.ValidatorFactory is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.MigrationEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.TriggerManagementEJBImpl.ValidatorFactory is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.TriggerManagementEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.AccessLogEJBImpl.ValidatorFactory is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.AccessLogEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ProcessJobEJBImpl.Validator is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ProcessJobEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.RepositoryEJBImpl.Validator is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.RepositoryEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.MigrationEJBImpl.Validator is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.MigrationEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.RepositoryStorageEJBImpl.Validator is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.RepositoryStorageEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ProcessHelperEJBImpl.Validator is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.ProcessHelperEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.SchedulerEJBImpl.ValidatorFactory is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.SchedulerEJBImpl]",
"jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.RepositoryStorageEJBImpl.ValidatorFactory is missing [jboss.naming.context.java.comp.\"RapidMiner-Server-CE-1.3.015\".RapidAnalytics_EJB.RepositoryStorageEJBImpl]"
}0 -
you can still use the installer. The .bat script only starts the installer with the java location.
You can just type in java -jar RapidMiner-Server-CE-Installer-1.3.015.jar and you are good to go.
The installer installs the preconfigured JBoss, i.e. with all additional libraries needed by RapidMiner Server, as well as configuring it with your settings. You really do not want to do that manually unless you have a lot of experience setting up application servers for various applications.
Marco0 -
Mmm...
I'm not lucky ;D
I followed the wizard and it was all right.
When I launch the "run" script and I have looked this error
It's the same error saw before...
Caused by: java.lang.IllegalStateException: Failed to find ContainerDependencyMetaData for interface: de.rapidanalytics.ejb.service.ServiceDataSourceRegistry
at org.jboss.deployment.MappedReferenceMetaDataResolverDeployer.resolveEjbInterface(MappedReferenceMetaDataResolverDeployer.java:1146)
at org.jboss.deployment.MappedReferenceMetaDataResolverDeployer.resolveEjbLocalRefs(MappedReferenceMetaDataResolverDeployer.java:877)
at org.jboss.deployment.MappedReferenceMetaDataResolverDeployer.resolve(MappedReferenceMetaDataResolverDeployer.java:743)
at org.jboss.deployment.MappedReferenceMetaDataResolverDeployer.internalDeploy(MappedReferenceMetaDataResolverDeployer.java:170)0 -
could you please provide the entire server.log and boot.log? You can delete them before attempting to start the server so they only contain the latest failure.
Marco0 -
Marco,
There was a my error.
When I launch the script there was setting my JBOSS_HOME.
I removed my enviroment variable like this
and everything has started correctly!
sh-3.2# JBOSS_HOME=
