Why is this marked as [SOLVED]? Is the one reply the correct answer? I'm having the same problem.
Please have a look at this KB article:
http://community.rapidminer.com/t5/RapidMiner-Studio-Knowledge-Base/Text-Mining-and-the-Word-List/ta-p/31723
~Martin
To build on what @mschmitz's knowledge base post, once you do your text transformations (i.e. tokenize, filter stop words, etc) in the Process Documents operator, many words will be stripped out of the corpus (i.e. the, a, lol). The TDIDF values of the remaining words get passed downstream via the EXA port to your machine learning algorithm. It will have "X" columns.
The problem comes in when your testing set gets processes and there are "X + n" columns to apply your model too, then the process breaks. Hence the passing the Wordlist from WOR port to the testing set. This way only the columns you trained your model one will be selected for the testing set.
