RM 5.xx hangs when exception occurs
marcin_blachnik
New Altair Community Member
I think it is a bug:
and it is related to the RapidMiner version 5.xx. For example it appears in version 5.13 and 5.15
Whenever an exception appears inside a loop, it doesn't influence next iteration. However, if there is any operator inside the loop which is conected to the output of operator throwing an exception the system hangs
This is shown in the example process:
Will it be possible that you correct it in the version 5
Best
Marcin
In RM 6.x this problem is solved.
<process version="5.3.013">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="5.3.013" expanded="true" height="60" name="Retrieve Iris" width="90" x="309" y="122">
<parameter key="repository_entry" value="//Samples/data/Iris"/>
<operator activated="true" class="loop_parameters" compatibility="5.3.013" expanded="true" height="76" name="Loop Parameters" width="90" x="450" y="119">
<list key="parameters">
<parameter key="Generate Macro (10).use_standard_constants" value="false"/>
</list>
<parameter key="parallelize_subprocess" value="true"/>
<operator activated="true" class="generate_macro" compatibility="5.3.013" expanded="true" height="76" name="Generate Macro (10)" width="90" x="183" y="272">
<parameter key="b_b" value="%{a_a}*5"/>
</list>
<parameter key="use_standard_constants" value="false"/>
<operator activated="true" class="log" compatibility="5.3.013" expanded="true" height="76" name="Log" width="90" x="421" y="277">
<list key="log">
<parameter key="dataset" value="operator.Generate Macro (10).value.applycount"/>
</list>
<connect from_port="input 1" to_op="Generate Macro (10)" to_port="through 1"/>
<connect from_op="Generate Macro (10)" from_port="through 1" to_op="Log" to_port="through 1"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
<connect from_op="Retrieve Iris" from_port="output" to_op="Loop Parameters" to_port="input 1"/>
</process>
</process>
Best
Marcin
while we will fix critical showstoppers in RM 5, I'm afraid this does not classify.. You are very welcome to create a pull request with the fix in Github though!
Marco0
