<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="subprocess" compatibility="5.3.015" expanded="true" height="76" name="Get important Attributes" width="90" x="313" y="30"> <process expanded="true"> <operator activated="true" class="subprocess" compatibility="5.3.015" expanded="true" height="76" name="Periodical Log (4)" width="90" x="179" y="30"> <process expanded="true"> <operator activated="true" class="multiply" compatibility="5.3.015" expanded="true" height="76" name="Multiply (22)" width="90" x="45" y="30"/> <operator activated="true" class="subprocess" compatibility="5.3.015" expanded="true" height="76" name="Min (2)" width="90" x="179" y="30"> <process expanded="true"> <operator activated="true" class="select_attributes" compatibility="5.3.015" expanded="true" height="76" name="Get Min (2)" width="90" x="45" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|Min|D_Min"/> </operator> <operator activated="true" class="optimize_selection_forward" compatibility="5.3.015" expanded="true" height="94" name="Forward Selection (50)" width="90" x="246" y="30"> <process expanded="true"> <operator activated="true" class="x_validation" compatibility="5.3.015" expanded="true" height="112" name="Validation (49)" width="90" x="45" y="30"> <process expanded="true"> <operator activated="true" class="naive_bayes_kernel" compatibility="5.3.015" expanded="true" height="76" name="Karnel Bayes (9)" width="90" x="178" y="30"/> <connect from_port="training" to_op="Karnel Bayes (9)" to_port="training set"/> <connect from_op="Karnel Bayes (9)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.015" expanded="true" height="76" name="Apply Model (51)" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.3.015" expanded="true" height="76" name="Perf Min Forward (7)" width="90" x="283" y="30"/> <connect from_port="model" to_op="Apply Model (51)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (51)" to_port="unlabelled data"/> <connect from_op="Apply Model (51)" from_port="labelled data" to_op="Perf Min Forward (7)" to_port="labelled data"/> <connect from_op="Perf Min Forward (7)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Validation (49)" to_port="training"/> <connect from_op="Validation (49)" from_port="averagable 1" to_port="performance"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> </process> </operator> <connect from_port="in 1" to_op="Get Min (2)" to_port="example set input"/> <connect from_op="Get Min (2)" from_port="example set output" to_op="Forward Selection (50)" to_port="example set"/> <connect from_op="Forward Selection (50)" from_port="example set" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_port="in 1" to_op="Multiply (22)" to_port="input"/> <connect from_op="Multiply (22)" from_port="output 1" to_op="Min (2)" to_port="in 1"/> <connect from_op="Min (2)" from_port="out 1" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_port="in 1" to_op="Periodical Log (4)" to_port="in 1"/> <connect from_op="Periodical Log (4)" from_port="out 1" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
