kjoint2 problems
Long story and potentially many questions in the same post but all related to the same issue and I ned help! I can't seem to understand how my kjoint2 spherical connection between 2 RBODY is behaving. What I am trying to model is a suspension ball joint in Radioss and I want the rotation to be limited to a certain maximum angle in ANY direction from vertical (creating a conical shaped limit envelop). I created a simple problem to resolve my issues but it doesn't seem to work.
I cerated 2 node reference systems in such a way that they move together and that their Z axis is always coaxial. I then limited my kjoint2 in Saz- and Saz+ to ±1 rad but it does not behave as desired. When I plot my TH/spring, I can see that RZ of my spring DOES respect the 1 rad angle limit. But this does not make sense with the visual behavior and the true angle that I can plot in Hyperview that cleary goes over 1 rad. Also Rx and Ry are showing rotation which again does not make sence with the visual behavior.
Any help to resolve this is appreciated!
Thanks
All my simple model files:
We are working on your query and will update you very soon.
0 -
Hi, thanks for the answer but it does not answer my question. I know how a sperical joint is suppose to behave... all rotations are free! No need to explain that to me.
What I am pointing out is that I want to limit the angular articulation of my srping in a certain way and although the moving skew /MOV that I created are visually moving correctly (i.e. their Z axis are always coaxial - see gif image above), the spring does not seem to follow my skews correctly.
Why is my kjoint2 not behaving as I would expect?
