GSP max gap not working
User: "mleece"
New Altair Community Member
Updated by Jocelyn
Hi all,
I'm attempting to use the GSP operator to extract some patterns from some data, but decided to test it on a simple set first to be sure I understand it. For the most part it seems to be correct, with the sliding window aggregating things appropriately and such, but the gap parameters don't seem to be being used. My data looks like:
customer_id, time, 1, 2, 3, 4, 5
1, 1.0, 1, 0, 0, 0, 0
1, 2.0, 0, 1, 0, 0, 0
1, 15.0, 0, 0, 1, 1, 0
2, 1.0, 1, 1, 0, 0, 0
2, 20.0, 0, 0, 0, 0, 1
2, 50.0, 0, 0, 1, 0, 0
When I import it, I'm making sure to set the feature columns to binomials.
When min support is 1, window size is 0, min gap is 0, and max gap is 100 (basically eliminating the meaningfulness of these parameters), I get <1> <3> and <2> <3>, which I would expect. However, if I drop the max gap to 20, both of them should drop out, since they aren't supported by customer 2 anymore, but I still get both of those patterns. Could I be doing something incorrectly, or are these parameters not implemented yet?
<process version="6.0.002">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
   <process expanded="true">
     <operator activated="true" class="retrieve" compatibility="6.0.002" expanded="true" height="60" name="Retrieve GSPinput" width="90" x="112" y="120">
       <parameter key="repository_entry" value="../data/GSPinput"/>
     <operator activated="true" class="generalized_sequential_patterns" compatibility="6.0.002" expanded="true" height="76" name="GSP" width="90" x="447" y="120">
       <parameter key="customer_id" value="customer_id"/>
       <parameter key="time_attribute" value="time"/>
       <parameter key="min_support" value="0.8"/>
       <parameter key="window_size" value="0.0"/>
       <parameter key="max_gap" value="10.0"/>
       <parameter key="min_gap" value="0.0"/>
       <parameter key="positive_value" value="1"/>
     <connect from_op="Retrieve GSPinput" from_port="output" to_op="GSP" to_port="example set"/>
     <connect from_op="GSP" from_port="patterns" to_port="result 1"/>
   </process>
</process>
Comments
No comments on this post.
