Hello, I have a suspension arm with a ball joint modeled in Radioss. My ball joint is modeled as a beam element connected to a zero length SPRING2N with very high translation rigidity and 0 torsional rigidity.
I would like to be able to show the reaction force acting in my SPRING2N as a vector to appreciated visually and in one glance its orientation in space. I can use an output block /TH/SPRING to plot the magnitude but this does not provide the orientation. I tried /ANIM/VECT but none of the options seem to offer what I am looking for. I also tried /ANIM/SPRING/FORC, but I can't find 'where' this result is plotted (vector, contour?). Any help on how I can do what I want? Thanks
