I am trying to trouble shoot a problem I am having with a kjoint2 in Radioss. Can you help me understand the way the initial angle is outputed in the starter file? I use two node reference systems (skew_ID1 and skew_ID2 in kjoint2 card) that have a rotation between their Z axis (see image below). The rotation can be seen in the TH/spring (~0.5rad) when I plot it in Hyperview but I can't seem to understand how it is showed in the starter file (all numbers below 'initial angle' are 0?). Can you help me understand the starter file info please?
Also see my other post:
