<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="6.0.002" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30"> <parameter key="csv_file" value="C:\Users\username\Desktop\test.csv"/> <parameter key="column_separators" value=","/> <parameter key="date_format" value="yyyy-MM-dd:HH:mm"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"/> <parameter key="encoding" value="UTF-8"/> <list key="data_set_meta_data_information"> <parameter key="0" value="att1.true.polynominal.attribute"/> <parameter key="1" value="att2.true.binominal.attribute"/> <parameter key="2" value="att3.true.binominal.attribute"/> <parameter key="3" value="att4.true.integer.attribute"/> <parameter key="4" value="att5.true.real.attribute"/> <parameter key="5" value="att6.true.attribute_value.attribute"/> <parameter key="6" value="att7.true.attribute_value.attribute"/> <parameter key="7" value="att8.true.binominal.attribute"/> <parameter key="8" value="att9.true.binominal.attribute"/> </list> </operator> <operator activated="true" class="nominal_to_date" compatibility="6.0.002" expanded="true" height="76" name="Nominal to Date" width="90" x="179" y="30"> <parameter key="attribute_name" value="att8"/> <parameter key="date_format" value="yyyy-MM-dd"/> </operator> <operator activated="true" class="nominal_to_date" compatibility="6.0.002" expanded="true" height="76" name="Nominal to Date (2)" width="90" x="313" y="30"> <parameter key="attribute_name" value="att9"/> <parameter key="date_type" value="time"/> <parameter key="date_format" value="HH:mm"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Nominal to Date" to_port="example set input"/> <connect from_op="Nominal to Date" from_port="example set output" to_op="Nominal to Date (2)" to_port="example set input"/> <connect from_op="Nominal to Date (2)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
