I have a text mining process started that I've been able to use with no problems when I run it on my desktop, but when I tried moving it over to the server so it could better accommodate more data later, it breaks down at the text processing step. Here is the process I was using:
<process version="5.3.015">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve CCC Sample 2" width="90" x="45" y="30">
<parameter key="repository_entry" value="CCC Sample 3"/>
<operator activated="true" class="generate_attributes" compatibility="5.3.015" expanded="true" height="76" name="Generate Attributes" width="90" x="179" y="30">
<parameter key="COMPL2" value="upper(COMPL)"/>
</list>
<operator activated="true" class="select_attributes" compatibility="5.3.015" expanded="true" height="76" name="Select Attributes" width="90" x="313" y="30">
<parameter key="attribute" value="COMPL2"/>
<operator activated="true" class="nominal_to_text" compatibility="5.3.015" expanded="true" height="76" name="Nominal to Text" width="90" x="447" y="30"/>
<operator activated="true" class="filter_examples" compatibility="5.3.015" expanded="true" height="76" name="Filter Examples" width="90" x="581" y="30">
<parameter key="condition_class" value="no_missing_attributes"/>
<operator activated="true" class="text:process_document_from_data" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Data" width="90" x="715" y="30">
<parameter key="keep_text" value="true"/>
<list key="specify_weights"/>
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize" width="90" x="112" y="75"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_port="document 1"/>
</process>
<connect from_op="Retrieve CCC Sample 2" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Nominal to Text" to_port="example set input"/>
<connect from_op="Nominal to Text" from_port="example set output" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_port="result 1"/>
<connect from_op="Process Documents from Data" from_port="word list" to_port="result 2"/>
</process>
</process>
When I try to run it on the server, though, I get the following error message:
SEVERE: Process failed: com.rapidminer.operator.UserError: The dummy operator Process Documents from Data (replacing text:process_document_from_data) cannot be executed.
Any thoughts as to how I can fix this?
Thanks
