sgenzer wrote:hi...is there any way to debug the Enrich Data by Webservice operator when it fails? I would to see the JSONpath that it is sending out in a POST request, and the actually reply from the server with the error code. I can do it in curl but not via the RapidMiner interface.
In a similar vein, is there a way to send a curl request directly from RM?
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.1.000-BETA"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="parallelize_main_process" value="false"/> <process expanded="true"> <operator activated="true" class="productivity:execute_program" compatibility="7.1.000-BETA" expanded="true" height="103" name="Execute Program" width="90" x="112" y="85"> <parameter key="command" value="cmd /c java -version"/> <parameter key="log_stdout" value="true"/> <parameter key="log_stderr" value="true"/> <list key="env_variables"/> </operator> <operator activated="true" class="text:read_document" compatibility="7.0.000" expanded="true" height="68" name="Read Document (2)" width="90" x="380" y="136"> <parameter key="extract_text_only" value="true"/> <parameter key="use_file_extension_as_type" value="true"/> <parameter key="content_type" value="txt"/> <parameter key="encoding" value="SYSTEM"/> </operator> <operator activated="true" class="text:read_document" compatibility="7.0.000" expanded="true" height="68" name="Read Document" width="90" x="380" y="34"> <parameter key="extract_text_only" value="true"/> <parameter key="use_file_extension_as_type" value="true"/> <parameter key="content_type" value="txt"/> <parameter key="encoding" value="SYSTEM"/> </operator> <connect from_op="Execute Program" from_port="out" to_op="Read Document" to_port="file"/> <connect from_op="Execute Program" from_port="err" to_op="Read Document (2)" to_port="file"/> <connect from_op="Read Document (2)" from_port="output" to_port="result 2"/> <connect from_op="Read Document" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.0.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.0.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="productivity:execute_program" compatibility="7.0.001" expanded="true" height="103" name="Execute Program" width="90" x="112" y="34"> <parameter key="command" value="ls /tmp"/> <list key="env_variables"/> </operator> <operator activated="true" class="text:read_document" compatibility="6.5.000" expanded="true" height="68" name="Read stdout" width="90" x="380" y="34"/> <operator activated="true" class="text:read_document" compatibility="6.5.000" expanded="true" height="68" name="Read stderr" width="90" x="514" y="85"/> <connect from_op="Execute Program" from_port="out" to_op="Read stdout" to_port="file"/> <connect from_op="Execute Program" from_port="err" to_op="Read stderr" to_port="file"/> <connect from_op="Read stdout" from_port="output" to_port="result 1"/> <connect from_op="Read stderr" from_port="output" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
