Hi! When I set in css_location my css ("https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/css/bootstrap.min.css"). The generated URL is /internal/rest/resourses/https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/css/bootstrap.min.css, how to change "/internal/rest/resourses/" or where are this path?
Thanks
Hi Sebastian,
I don't know if your problem is solved by now but I described the solution with some screenshots in this post.
Hope it helps,
Edin
