<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.0.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.0.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="7.0.001" expanded="true" height="68" name="Retrieve Sonar" width="90" x="45" y="85"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="generate_id" compatibility="7.0.001" expanded="true" height="82" name="Generate ID" width="90" x="45" y="187"/> <operator activated="true" class="sample" compatibility="7.0.001" expanded="true" height="82" name="Sample (2)" width="90" x="179" y="85"> <parameter key="sample" value="probability"/> <parameter key="balance_data" value="true"/> <list key="sample_size_per_class"/> <list key="sample_ratio_per_class"/> <list key="sample_probability_per_class"> <parameter key="Mine" value="0.2"/> <parameter key="Rock" value="0.5"/> </list> <description align="center" color="transparent" colored="false" width="126">This undersamples the class 'Mine' to make it even more difficult to detect mines</description> </operator> <operator activated="true" class="subprocess" compatibility="7.0.001" expanded="true" height="103" name="StackingMagic" width="90" x="380" y="34"> <process expanded="true"> <operator activated="true" class="multiply" compatibility="7.0.001" expanded="true" height="124" name="Multiply" width="90" x="45" y="85"/> <operator activated="true" class="stacking" compatibility="7.0.001" expanded="true" height="68" name="Stacking" width="90" x="179" y="34"> <parameter key="keep_all_attributes" value="false"/> <process expanded="true"> <operator activated="true" class="extract_macro" compatibility="7.0.001" expanded="true" height="68" name="Extract Macro" width="90" x="45" y="34"> <parameter key="macro" value="posClass"/> <parameter key="macro_type" value="statistics"/> <parameter key="statistics" value="count"/> <parameter key="attribute_name" value="class"/> <parameter key="attribute_value" value="Mine"/> <list key="additional_macros"/> </operator> <operator activated="true" class="loop" compatibility="7.0.001" expanded="true" height="82" name="Loop Trees" width="90" x="179" y="34"> <parameter key="set_iteration_macro" value="true"/> <parameter key="iterations" value="20"/> <process expanded="true"> <operator activated="true" class="sample" compatibility="7.0.001" expanded="true" height="82" name="Sample" width="90" x="45" y="34"> <parameter key="balance_data" value="true"/> <list key="sample_size_per_class"> <parameter key="Mine" value="%{posClass}"/> <parameter key="Rock" value="%{posClass}"/> </list> <list key="sample_ratio_per_class"/> <list key="sample_probability_per_class"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="%{iteration}"/> </operator> <operator activated="true" class="multiply" compatibility="7.0.001" expanded="true" height="82" name="Multiply (2)" width="90" x="112" y="136"> <description align="center" color="transparent" colored="false" width="126">You can add other models as you like here.</description> </operator> <operator activated="true" class="parallel_random_forest" compatibility="7.0.001" expanded="true" height="82" name="Random Forest" width="90" x="246" y="136"/> <connect from_port="input 1" to_op="Sample" to_port="example set input"/> <connect from_op="Sample" from_port="example set output" to_op="Multiply (2)" to_port="input"/> <connect from_op="Multiply (2)" from_port="output 1" to_op="Random Forest" to_port="training set"/> <connect from_op="Random Forest" from_port="model" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> <description align="center" color="transparent" colored="false" width="126">Each loop builds a new tree using a different balanced data sample. The loop iteration is used as the RandomSeed so the more loops, the more trees.</description> </operator> <connect from_port="training set 1" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Loop Trees" to_port="input 1"/> <connect from_op="Loop Trees" from_port="output 1" to_port="base model 1"/> <portSpacing port="source_training set 1" spacing="0"/> <portSpacing port="source_training set 2" spacing="0"/> <portSpacing port="sink_base model 1" spacing="0"/> <portSpacing port="sink_base model 2" spacing="0"/> </process> <process expanded="true"> <operator activated="false" class="naive_bayes" compatibility="7.0.001" expanded="true" height="82" name="Naive Bayes" width="90" x="45" y="85"/> <operator activated="true" class="weka:W-Logistic" compatibility="7.0.000" expanded="true" height="82" name="W-Logistic" width="90" x="45" y="187"/> <connect from_port="stacking examples" to_op="W-Logistic" to_port="training set"/> <connect from_op="W-Logistic" from_port="model" to_port="stacking model"/> <portSpacing port="source_stacking examples" spacing="0"/> <portSpacing port="sink_stacking model" spacing="0"/> </process> <description align="center" color="transparent" colored="false" width="126">This is the operator where things are interesting.</description> </operator> <operator activated="true" class="set_minus" compatibility="7.0.001" expanded="true" height="82" name="Set Minus" width="90" x="179" y="289"> <description align="center" color="transparent" colored="false" width="126">Keeps it fair (ineffect it's a split test, but I went the complicated way)</description> </operator> <operator activated="true" class="apply_model" compatibility="7.0.001" expanded="true" height="82" name="Apply Model" width="90" x="313" y="136"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="7.0.001" expanded="true" height="82" name="Performance Loop Stacking" width="90" x="380" y="34"/> <connect from_port="in 1" to_op="Multiply" to_port="input"/> <connect from_port="in 2" to_op="Set Minus" to_port="example set input"/> <connect from_op="Multiply" from_port="output 1" to_op="Stacking" to_port="training set"/> <connect from_op="Multiply" from_port="output 2" to_op="Set Minus" to_port="subtrahend"/> <connect from_op="Stacking" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Set Minus" from_port="example set output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance Loop Stacking" to_port="labelled data"/> <connect from_op="Apply Model" from_port="model" to_port="out 1"/> <connect from_op="Performance Loop Stacking" from_port="performance" to_port="out 2"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="189"/> <portSpacing port="source_in 3" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> <portSpacing port="sink_out 3" spacing="0"/> </process> <description align="center" color="transparent" colored="false" width="126">This uses a loop to generate many decision trees using different samples of the data for a more complete picture.</description> </operator> <connect from_op="Retrieve Sonar" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Sample (2)" to_port="example set input"/> <connect from_op="Sample (2)" from_port="example set output" to_op="StackingMagic" to_port="in 1"/> <connect from_op="Sample (2)" from_port="original" to_op="StackingMagic" to_port="in 2"/> <connect from_op="StackingMagic" from_port="out 1" to_port="result 1"/> <connect from_op="StackingMagic" from_port="out 2" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
