Hi all,
I have some hundreds text files, some of them over 1GB which I have to process but even for some dozens of files max 50 MB large each I get after some time an error.:
| This process would need more than the maximum amount of available memory. ... |
I have a notebook with 8GB RAM and I can see that RM uses about 5GB.
Is there any way to get this working?
Is Radoop able to do something like this?
I cannot find it in the extensions.
Here is my XML:
<process version="5.3.015">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="text:process_document_from_file" compatibility="5.3.002" expanded="true" height="76" name="Process Documents from Files (2)" width="90" x="45" y="30">
<list key="text_directories">
<parameter key="testhtml" value="E:\#APPSDATA\RapidMiner\test5"/>
</list>
<parameter key="file_pattern" value="*.txt"/>
<parameter key="encoding" value="UTF-8"/>
<parameter key="vector_creation" value="Term Occurrences"/>
<parameter key="keep_text" value="true"/>
<parameter key="prune_below_absolute" value="0"/>
<parameter key="prune_above_absolute" value="10"/>
<parameter key="datamanagement" value="float_array"/>
<operator activated="true" class="web:extract_html_text_content" compatibility="5.3.001" expanded="true" height="60" name="Extract Content" width="90" x="45" y="30">
<parameter key="minimum_text_block_length" value="3"/>
<operator activated="true" class="text:tokenize" compatibility="5.3.002" expanded="true" height="60" name="Tokenize (2)" width="90" x="179" y="30"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.3.002" expanded="true" height="60" name="Filter Tokens (2)" width="90" x="313" y="30">
<parameter key="min_chars" value="3"/>
<parameter key="max_chars" value="30"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="380" y="165"/>
<operator activated="true" class="text:filter_stopwords_german" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (German)" width="90" x="514" y="165"/>
<operator activated="true" class="text:filter_stopwords_french" compatibility="5.3.002" expanded="true" height="60" name="Filter Stopwords (French)" width="90" x="648" y="165"/>
<operator activated="true" class="text:transform_cases" compatibility="5.3.002" expanded="true" height="60" name="Transform Cases (2)" width="90" x="648" y="30"/>
<connect from_port="document" to_op="Extract Content" to_port="document"/>
<connect from_op="Extract Content" from_port="document" to_op="Tokenize (2)" to_port="document"/>
<connect from_op="Tokenize (2)" from_port="document" to_op="Filter Tokens (2)" to_port="document"/>
<connect from_op="Filter Tokens (2)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Stopwords (German)" to_port="document"/>
<connect from_op="Filter Stopwords (German)" from_port="document" to_op="Filter Stopwords (French)" to_port="document"/>
<connect from_op="Filter Stopwords (French)" from_port="document" to_op="Transform Cases (2)" to_port="document"/>
<connect from_op="Transform Cases (2)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="loop_batches" compatibility="5.3.015" expanded="true" height="60" name="Loop Batches" width="90" x="179" y="30">
<parameter key="batch_size" value="100"/>
<portSpacing port="source_exampleSet" spacing="0"/>
</process>
<operator activated="true" class="transpose" compatibility="5.3.015" expanded="true" height="76" name="Transpose" width="90" x="380" y="30"/>
<operator activated="true" class="write_excel" compatibility="5.3.015" expanded="true" height="76" name="Write Excel" width="90" x="581" y="30">
<parameter key="excel_file" value="E:\#APPSDATA\RapidMiner\excel\20140114a"/>
<parameter key="file_format" value="xlsx"/>
<connect from_op="Process Documents from Files (2)" from_port="example set" to_op="Loop Batches" to_port="example set"/>
<connect from_op="Loop Batches" from_port="example set" to_op="Transpose" to_port="example set input"/>
<connect from_op="Transpose" from_port="example set output" to_op="Write Excel" to_port="input"/>
<connect from_op="Write Excel" from_port="through" to_port="result 1"/>
</process>
</process>
