<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="nominal_to_date" compatibility="6.0.002" expanded="true" height="76" name="Nominal to Date" width="90" x="246" y="30"> <parameter key="attribute_name" value="Test"/> <parameter key="date_format" value="yyyyMMdd"/> </operator> <connect from_op="Nominal to Date" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
