I just installed rapidminer-server on a linux machine which seems to work. However, I cannot access the web interface to manage the server.
I followed the installer GUI and installed rapidminer-server on my local machine. The MySQL connection to 'localhost' worked without any problems. I did not configure a SMTP server. Installation was done into my local home folder without root privileges. Startup looks like this:
[10:52:54]~/tools/rapidminer-server/bin$ ./standalone.sh
JBoss Bootstrap Environment
JBOSS_HOME: /home/buschjae/tools/rapidminer-server
JAVA: /usr/lib/jvm/java-8-openjdk-amd64/bin/java
JAVA_OPTS: -server -XX:+UseCompressedOops -Xms512m -Xmx23079m -XX:MaxPermSize=256m -XX:+UseG1GC -XX:MaxGCPauseMillis=50 -Djava.net.preferIPv4Stack=true -Dorg.jboss.resolver.warning=true -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Djboss.modules.system.pkgs=org.jboss.byteman -Djava.awt.headless=true -Djboss.server.default.config=standalone.xml
OpenJDK 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was removed in 8.0
10:52:56,507 INFO [org.jboss.modules] (main) JBoss Modules version 1.2.0.CR1
10:52:56,632 INFO [org.jboss.msc] (main) JBoss MSC version 1.0.4.GA
10:52:56,676 INFO [org.jboss.as] (MSC service thread 1-6) JBAS015899: JBoss AS 7.2.0.Alpha1-redhat-4 "Janus" starting
The server.log file gives me:
[11:04:28]~/tools/rapidminer-server/standalone/log$ cat server.log
10:52:56,681 DEBUG [org.jboss.as.config] (MSC service thread 1-6) Configured system properties:
[Standalone] =
awt.toolkit = sun.awt.X11.XToolkit
file.encoding = UTF-8
file.encoding.pkg = sun.io
file.separator = /
java.awt.graphicsenv = sun.awt.X11GraphicsEnvironment
java.awt.headless = true
java.awt.printerjob = sun.print.PSPrinterJob
java.class.path = /home/buschjae/tools/rapidminer-server/jboss-modules.jar
java.class.version = 52.0
java.endorsed.dirs = /usr/lib/jvm/java-8-openjdk-amd64/jre/lib/endorsed
java.ext.dirs = /usr/lib/jvm/java-8-openjdk-amd64/jre/lib/ext:/usr/java/packages/lib/ext
java.home = /usr/lib/jvm/java-8-openjdk-amd64/jre
java.io.tmpdir = /tmp
java.library.path = /usr/java/packages/lib/amd64:/usr/lib/x86_64-linux-gnu/jni:/lib/x86_64-linux-gnu:/usr/lib/x86_64-linux-gnu:/usr/lib/jni:/lib:/usr/lib
java.net.preferIPv4Stack = true
java.runtime.name = OpenJDK Runtime Environment
java.runtime.version = 1.8.0_66-internal-b17
java.specification.name = Java Platform API Specification
java.specification.vendor = Oracle Corporation
java.specification.version = 1.8
java.util.logging.manager = org.jboss.logmanager.LogManager
java.vendor = Oracle Corporation
java.vendor.url = http://java.oracle.com/
java.vendor.url.bug = http://bugreport.sun.com/bugreport/
java.version = 1.8.0_66-internal
java.vm.info = mixed mode
java.vm.name = OpenJDK 64-Bit Server VM
java.vm.specification.name = Java Virtual Machine Specification
java.vm.specification.vendor = Oracle Corporation
java.vm.specification.version = 1.8
java.vm.vendor = Oracle Corporation
java.vm.version = 25.66-b17
javax.management.builder.initial = org.jboss.as.jmx.PluggableMBeanServerBuilder
javax.xml.datatype.DatatypeFactory = __redirected.__DatatypeFactory
javax.xml.parsers.DocumentBuilderFactory = __redirected.__DocumentBuilderFactory
javax.xml.parsers.SAXParserFactory = __redirected.__SAXParserFactory
javax.xml.stream.XMLEventFactory = __redirected.__XMLEventFactory
javax.xml.stream.XMLInputFactory = __redirected.__XMLInputFactory
javax.xml.stream.XMLOutputFactory = __redirected.__XMLOutputFactory
javax.xml.transform.TransformerFactory = __redirected.__TransformerFactory
javax.xml.validation.SchemaFactory:http://www.w3.org/2001/XMLSchema = __redirected.__SchemaFactory
javax.xml.xpath.XPathFactory:http://java.sun.com/jaxp/xpath/dom = __redirected.__XPathFactory
jboss.home.dir = /home/buschjae/tools/rapidminer-server
jboss.host.name = kimme
jboss.modules.dir = /home/buschjae/tools/rapidminer-server/modules
jboss.modules.system.pkgs = org.jboss.byteman
jboss.node.name = kimme
jboss.qualified.host.name = kimme.cs.uni-dortmund.de
jboss.server.base.dir = /home/buschjae/tools/rapidminer-server/standalone
jboss.server.config.dir = /home/buschjae/tools/rapidminer-server/standalone/configuration
jboss.server.data.dir = /home/buschjae/tools/rapidminer-server/standalone/data
jboss.server.default.config = standalone.xml
jboss.server.deploy.dir = /home/buschjae/tools/rapidminer-server/standalone/data/content
jboss.server.log.dir = /home/buschjae/tools/rapidminer-server/standalone/log
jboss.server.name = kimme
jboss.server.persist.config = true
jboss.server.temp.dir = /home/buschjae/tools/rapidminer-server/standalone/tmp
line.separator =
logging.configuration = file:/home/buschjae/tools/rapidminer-server/standalone/configuration/logging.properties
module.path = /home/buschjae/tools/rapidminer-server/modules
org.jboss.boot.log.file = /home/buschjae/tools/rapidminer-server/standalone/log/server.log
org.jboss.resolver.warning = true
org.xml.sax.driver = __redirected.__XMLReaderFactory
os.arch = amd64
os.name = Linux
os.version = 4.2.0-34-generic
path.separator = :
sun.arch.data.model = 64
sun.boot.class.path = /usr/lib/jvm/java-8-openjdk-amd64/jre/lib/resources.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/rt.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/sunrsasign.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/jsse.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/jce.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/charsets.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/lib/jfr.jar:/usr/lib/jvm/java-8-openjdk-amd64/jre/classes:/home/buschjae/tools/rapidminer-server/jboss-modules.jar
sun.boot.library.path = /usr/lib/jvm/java-8-openjdk-amd64/jre/lib/amd64
sun.cpu.endian = little
sun.cpu.isalist =
sun.io.unicode.encoding = UnicodeLittle
sun.java.command = /home/buschjae/tools/rapidminer-server/jboss-modules.jar -mp /home/buschjae/tools/rapidminer-server/modules -jaxpmodule javax.xml.jaxp-provider org.jboss.as.standalone -Djboss.home.dir=/home/buschjae/tools/rapidminer-server -Djboss.server.base.dir=/home/buschjae/tools/rapidminer-server/standalone
sun.java.launcher = SUN_STANDARD
sun.jnu.encoding = UTF-8
sun.management.compiler = HotSpot 64-Bit Tiered Compilers
sun.os.patch.level = unknown
sun.rmi.dgc.client.gcInterval = 3600000
sun.rmi.dgc.server.gcInterval = 3600000
user.country = US
user.dir = /home/buschjae/tools/rapidminer-server/bin
user.home = /home/buschjae
user.language = en
user.name = buschjae
user.timezone = Europe/Berlin
10:52:56,682 DEBUG [org.jboss.as.config] (MSC service thread 1-6) VM Arguments: -D[Standalone] -XX:+UseCompressedOops -Xms512m -Xmx23079m -XX:MaxPermSize=256m -XX:+UseG1GC -XX:MaxGCPauseMillis=50 -Djava.net.preferIPv4Stack=true -Dorg.jboss.resolver.warning=true -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Djboss.modules.system.pkgs=org.jboss.byteman -Djava.awt.headless=true -Djboss.server.default.config=standalone.xml -Dorg.jboss.boot.log.file=/home/buschjae/tools/rapidminer-server/standalone/log/server.log -Dlogging.configuration=file:/home/buschjae/tools/rapidminer-server/standalone/configuration/logging.properties -Xbootclasspath/a:/home/buschjae/tools/rapidminer-server/jboss-modules.jar
When I try to connect to to 'localhost:8080' from the same machine, I get "unable to connect". And indeed, 'lsof -i' doesnt show any port 8080. I double checked the configuration file
"standalone.xml" which contains
"<socket-binding name="http" port="8080"/>"
, so everything should be setup correct. However, I doesnt work
Some additional system information:
[11:11:20]~/tools/rapidminer-server/bin$ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=15.10
DISTRIB_CODENAME=wily
DISTRIB_DESCRIPTION="Ubuntu 15.10"
[11:12:00]~/tools/rapidminer-server/bin$ ps ax | grep mysql
3225 ? Ss 0:00 /bin/sh /usr/bin/mysqld_safe
3576 ? Sl 0:02 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --log-error=/var/log/mysql/error.log --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/run/mysqld/mysqld.sock --port=3306
7119 pts/14 S+ 0:00 grep --color=auto mysql
Any ideas why this isnt working?
