Dear everyone!
I'm currently trying to get a deeper knowledge about RM.
I just wanted to get 10 samples per category from a data set, which is a list of products. (There can be multiple products in one category)
What I did is the following:
retrieve the data
trim the data (as there are spaces before and after some words sometimes)
Set role "label" to the category attribute
Apply "Sample" Operator with absolute set to 10
Does someone know why the result doesn't show any examples?
P.S.: ID is set to be the product-id
Thanks!
<process version="7.0.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.0.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="7.0.001" expanded="true" height="68" name="Retrieve t123_product_import_23032016" width="90" x="45" y="85">
<parameter key="repository_entry" value="//tech123_win/t123_product_import_23032016"/>
<operator activated="true" class="trim" compatibility="7.0.001" expanded="true" height="82" name="Trim" width="90" x="112" y="187">
<parameter key="attribute" value="etim"/>
<operator activated="true" class="set_role" compatibility="7.0.001" expanded="true" height="82" name="Set Role" width="90" x="246" y="85">
<parameter key="attribute_name" value="etim"/>
<operator activated="true" class="sample" compatibility="7.0.001" expanded="true" height="82" name="Sample" width="90" x="447" y="136">
<parameter key="balance_data" value="true"/>
<list key="sample_size_per_class">
<parameter key="EC000993" value="5"/>
<parameter key="EC000058" value="5"/>
</list>
<list key="sample_ratio_per_class"/>
<list key="sample_probability_per_class"/>
<connect from_op="Retrieve t123_product_import_23032016" from_port="output" to_op="Trim" to_port="example set input"/>
<connect from_op="Trim" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Sample" to_port="example set input"/>
<connect from_op="Sample" from_port="example set output" to_port="result 1"/>
</process>
</process>
